Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Force and Force Coefficient
Like Tree2Likes
  • 1 Post By jakaranda
  • 1 Post By gfoam
Old   November 17, 2009, 01:59
Default Force and Force Coefficient
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi Foamers
I have a problem with force and force coefficient plotting.
I add this to end of cavity tutorial controlDict file
forces
type forces;
functionObjectLibs ("libforces.so"); //Lib to load
patches (fixedWalls); // change to your patch name
rhoInf 1.225; //Reference density for fluid
CofR (0.25 0 0); //Origin for moment calculations
forceCoeffs
type forceCoeffs;
patches (fixedWalls); //change to your patch name
rhoInf 1.225;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0.25 0 0);
magUInf 10.0;
lRef 1;
Aref 1;
and I solved it by icoFoam > log
and then when I type " gnuplot forceCoeffs -" I got this message
"forceCoeffs", line 10: warning: Skipping unreadable file "./forceCoeffs/0.0005/forceCoeffs.dat"
"forceCoeffs", line 10: No data in plot"
I think that I did not calculate force and force coefficient correctly.Can any one help me?
Thanks
Ata
ata is offline   Reply With Quote
Old   March 22, 2010, 12:02
jakaranda is on a distinguished road
Hello Ata,
the force.dat file is not in the right format for Gnuplot.
forces.dat has ( and ) which gnuplot can not deal with. you need to remove those.
jakaranda is offline   Reply With Quote
Old   March 23, 2010, 03:18
ata
ata's Avatar
ata kamyabi
Hi jakaranda
Thank you very much for your reply. Can you explain more for me.
I do not understand what I must to do?
Best regards
Old   March 24, 2010, 12:59
HEllo ata,
in order to hanve Gnuplot work you must remove all the parentheses.
Ru nthe following script
cat forces.dat | tr -d "("")" > forcesClean.dat
and that will create a forcesClean.dat file wihtout any parentheses which Gnuplot will read.
then wihtin gnuplot use plot "forcesClean.dat" using 1:2 to plot the numbers in the first 2 columns.
for Gnuplot info look at the following websites
http://www.duke.edu/~hpgavin/gnuplot.html
http://t16web.lanl.gov/Kawano/gnuplot/index-e.html
hope this helps
J
mo_na likes this.
Old   March 16, 2011, 11:08
jms
José
jms is on a distinguished road
Dear all,
I am using this function that it is needed in controlDict in orer to get the lift, drag and moment coefficients for a computation of the flow around an airfoil. The results I get for the lift and drag coefficients are very good compared to the reference I am using for both lift and drag coefficients but they are very bad for the moment coefficients. I use CofR=0.25*chord.
Any idea why I am getting this bad results?
Thanks,
José
jms is offline   Reply With Quote
Old   March 22, 2011, 05:45
fisch
fisch is on a distinguished road
i have two questions about the probes utility.
1. Is the return value of the probe just the cell midpoint value at the cell where the given probe point lies inside or is it interpolated?
2. What about movingMeshes? Are the probes fixed in space or are they moving with the grid? Do i have to make something on the probes relative/absolute like for velocities in the solver?
Thanks,
rupert
fisch is offline   Reply With Quote
Old   February 5, 2012, 12:35
Gonzalo
gfoam is on a distinguished road
Originally Posted by jms View Post
Dear all,
Thanks,
José
The moment coefficient in libforces.so, is possitive under the rule of the right hand, while in aeronautics, the pitching moment is possitive nose up. I think this may the cause of your differences.
Gonzalo
Tjcross31 likes this.
gfoam is offline   Reply With Quote
Old   April 8, 2012, 06:54
wangwei
buaawangwei is on a distinguished road
Hi jakaranda,
now I use the function of "force",This is my function as follows:
forces
type forceCoeffs;
functionObjectLibs ( "libforces.so" );
outputControl timeStep;
outputInterval 1;
patches
MAIN
//FLAP
//SLATUP
//SLATDOWN
//SLATWEI
pName p;
UName U;
rhoName rho;
log true;
rhoInf 1;
CofR ( 0 0 0 );
liftDir ( -0.104528463 0.994521895 0 );
dragDir ( 0.994521895 0.104528463 0 );
pitchAxis ( 0 0 1 );
magUInf 68;
lRef 0.457;
Aref 1.2933;
I have a question at "Aref"and "rhoRef".because now I compute an airfoil,so "lref" is the chord length,but I don't know how to compute the "ARef".And this a "compressible"case,so I also don't know how to define the "rhoInf".Thank you
buaawangwei is offline   Reply With Quote
Old   April 10, 2012, 20:41
Gonzalo
Aref is the chord of the airfoil by the lenght in the "z" direction of your problem. If your mesh is a 2D one then Aref=chord*1. The density is computed using the ideal gas law, with the pressure and temperature at freestream conditions.
Old   August 18, 2021, 13:44
Gabriel Felix
gabrielfelix is on a distinguished road
I wrote a code for plotting residuals, forces or both
You just gotta execute them at terminal:
./plotResiduals
./plotForces
./plotRF
plotResiduals:
#!/bin/bash
# Code for plotting residuals
foamLog log.simpleFoam >/dev/null
gnuplot -persist > /dev/null 2>&1 << EOF
set logscale y
set title "Residual vs. Iteration"
set xlabel "Iteration"
set ylabel "Residual"
plot "logs/Ux_0" with lines,\
"logs/Uy_0" with lines,\
"logs/Uz_0" with lines,\
"logs/p_0" with lines
EOF
plotForces:
#!/bin/bash
set logscale x
set title "Forces vs. Iteration"
set ylabel "Forces"
plot '<sed -e "s/[(,)]//g" ./postProcessing/forces/0/force_0.dat' using 1:2 with lines title 'Fx [N]',\
'<sed -e "s/[(,)]//g" ./postProcessing/forces/0/force_0.dat' using 1:3 with lines title 'Fy [N]',\
'<sed -e "s/[(,)]//g" ./postProcessing/forces/0/force_0.dat' using 1:4 with lines title 'Fz [N]'
EOF
plotRF:
#!/bin/bash
# Code for plotting residuals and forces
cat ./postProcessing/forces/0/force_0.dat | tr -d "("")" > ./forceClean.dat
set terminal wxt size 500,600
set multiplot
set size 1,0.5
set origin 0.0,0.5;
set logscale y
set logscale x
set ylabel "Residual";
"logs/p_0" with lines;
set origin 0.0,0.0;
unset logscale y
set ylabel "Forces";
unset multiplot
EOF
gabrielfelix is offline   Reply With Quote
What force vector in monitoring Lift Coefficient? pkoon FLUENT 3 November 6, 2008 00:40
The lift force coefficient in bubbly flow Kai Yan Main CFD Forum 1 November 4, 2008 13:54
Problem with lift force coefficient summer FLUENT 0 May 7, 2008 10:35
Lift force coefficient for 2-phase flow Summer FLUENT 0 April 29, 2008 17:58
Lift force or coefficient of lift Rola FLUENT 1 November 12, 2006 13:29
