Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Nusselt number over theta
Like Tree8Likes
Old   November 22, 2010, 04:41
Default Nusselt number over theta
Snehal Janwe
snehal is on a distinguished road
Hello everybody,
I have successfully simulated the case of flow around a circular cylinder with heat transfer using OpenFOAM.
For heat transfer I have calculated the nusselt number over the cylinder surface.
I just wanted to know, how can I plot Nusselt number over theta(angle 0-360).
Thanks in advance
snehal is offline   Reply With Quote
Old   November 22, 2010, 13:18
aerothermal's Avatar
Guilherme da Silva
aerothermal is on a distinguished road
Send a message via Skype™ to aerothermal
use paraFoam to do that
extract your cylinder boundary with extractBlock
plot on intersection and select appropriate axis (z?)
select variables...
Is your cylinder fully rough?
aerothermal is offline   Reply With Quote
Old   March 13, 2011, 03:57
Default calculating nusselt number
Maryam Mousazadeh
anijdon is on a distinguished road
hello ;
I added energy equation to simplefoam and simulated heat transfer around a cube but I don't know how to calculate nusselt number and plot it.all walls of the cube are under constant heat flux.
would you help me?
thanks.
anijdon is offline   Reply With Quote
Old   March 13, 2011, 10:25
Guilherme da Silva
Originally Posted by anijdon View Post
hello ;
would you help me?
thanks.
Hi anijdon,
See the tool,
 wallHeatFlux
I might solve your problem.
Let me know if you have difficulties.
regards,
aeroThermal
Goutam likes this.
Old   March 13, 2011, 15:05
Maryam Mousazadeh
thanks, do you mean wallHeatFluxLaminar utility?but it calculates wall heat flux which is my input data as boundary conditions and I don't need it.I think I need termal gradient to calculate h=q''/(Ts-T) >> Nu=hL/k. but I don't know how!!!
Old   March 16, 2011, 13:00
Guilherme da Silva
yes...of course you have the heat flux!
so it is simpler! do it in paraFoam...
1) extract your cylinder boundary with extractBlock
2) use calculator to evaluate \dot{q}^" / (DeltaT)
3) plot on intersection and select appropriate axis (z?)
4) select variables...
Regards,
aerothermal
Goutam and Sherlock_1812 like this.
Old   March 17, 2011, 04:46
Maryam Mousazadeh
hello.
thanks a lot . but my problem is that I don't know how to calculate DeltaT.
Old   March 17, 2011, 09:50
Guilherme da Silva
You can calculate that in paraFoam. Use Filter -> Calculator.
So it is possible to calculate (T-Tref) on it to generate a new field.
In order to get only T surface you will need to Filter -> ExtractBlock your patch.
maddalena and Goutam like this.
Old   March 17, 2011, 15:23
Maryam Mousazadeh
I'm sorry, it was so easy.thanks a lot for your helping.
excuse me, can we export the result of caculating to matlab or save the data in a separate file?(I'm not well in paraview)
thanks
kind regards
Old   March 17, 2011, 15:35
Guilherme da Silva
yes...just select your plot, click file -> save data.
it will save as .csv for external tools like excel, matlab or R Cran
Goutam likes this.
Old   March 18, 2011, 14:23
Maryam Mousazadeh
thank a lot for your guidance.
regards.
Old   April 9, 2011, 02:26
Maryam Mousazadeh
hello dear aerothermal;
excuse me, I have another problem with heat transfer in openfoam.
I want to simulate an incompressible nanofluid flow with heat transfer using simpleFoam (i.e. solver includes an energy equation).The conductivity of the fluid is temperature dependent . I don't know haw can modify the solver and case directories to these properties become temperature dependent ;I took down this threat in this site but I have not received any answer so far,
would you help me?
I attach special formula of nonofluids:
formuls.zip
kind regards
Old   November 10, 2011, 08:57
Guilherme da Silva
Dear Maryam,
your zip file is empty.
Regards,
aerothermal
Old   February 19, 2012, 08:34
Goutam Saha
Goutam is on a distinguished road
dear friends,
I have calculated the local Nusselt number. Please see the code.
How I will calculate the average Nusselt Number?
#include "fvCFD.H"
#include "hCombustionThermo.H"
#include "basicThermo.H"
#include "RASModel.H"
#include "wallFvPatch.H"
int main(int argc, char *argv[])
timeSelector::addOptions();
#include "setRootCase.H"
#include "createTime.H"
instantList timeDirs = timeSelector::select0(runTime, args);
#include "createMesh.H"
forAll(timeDirs, timeI)
runTime.setTime(timeDirs[timeI], timeI);
Info<< "Time = " << runTime.timeName() << endl;
mesh.readUpdate();
#include "createFields.H"
#include "readRefValues.H"
surfaceScalarField heatFlux
fvc::interpolate(RASModel->alphaEff())*fvc::snGrad(h)
const surfaceScalarField::GeometricBoundaryField& patchHeatFlux =
heatFlux.boundaryField();
Info<< "\nWall heat fluxes [W]" << endl;
forAll(patchHeatFlux, patchi)
if (typeid(mesh.boundary()[patchi]) == typeid(wallFvPatch))
Info<< mesh.boundary()[patchi].name()
<< sum
mesh.magSf().boundaryField()[patchi]
*patchHeatFlux[patchi]
<< endl;
Info<< endl;
volScalarField wallHeatFlux
IOobject
"wallHeatFlux",
runTime.timeName(),
mesh
mesh,
dimensionedScalar("wallHeatFlux", heatFlux.dimensions(), 0.0)
forAll(wallHeatFlux.boundaryField(), patchi)
wallHeatFlux.boundaryField()[patchi] = patchHeatFlux[patchi];
wallHeatFlux.write();
Info << "\nNusselt Number:" << endl;
volScalarField localNusselt
IOobject
"localNusselt",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("localNusselt",dimless,0.0)
forAll(localNusselt.boundaryField(),patchi)
localNusselt.boundaryField()[patchi] = length*patchHeatFlux[patchi]/((T_hot-T_ini)*k);
localNusselt.write();
Info<< "End" << endl;
return 0;
aerothermal likes this.
Goutam is offline   Reply With Quote
Old   March 22, 2012, 07:58
Default Average Nusselt
  #15
Guilherme da Silva
Two ways:
1) in your code, sum all your Nusselt number values for one patch (not all patches) times de area of each element; sum all areas of elements/cells of the same patch; divide the nusselt values sum by the area sum
2) in paraFoam, use filter "extractBlock" to extract the patch you want the average, use filter "integrate variables", it will open an spreadsheet, look for Area value in Cells or Points, look for Nusselt value in Cells or Points, divide Nusselt integrated value by the Area integrated value.
Regards,
aerothermal
Goutam likes this.
Old   December 3, 2015, 06:14
Unhappy
  #16
Mohammad Reza
Bana is on a distinguished road
Hi friends
I have a question, I want to calculate Nusselt number in a heated pipe at each cross section but for the temperature difference it needs to calculate the bulk temperature which requires computation of integral of U*T over each section (since my simulation is axisymmetric I need to calculate integration along radius instead). Do you have any idea on how to compute the integral in openfoam?
thanks in advance
Bana is offline   Reply With Quote
Old   June 6, 2016, 11:49
Scram_1 is on a distinguished road
Hey Bana,
Have you managed to figure out how to calculate the bulk temperature in openFOAM? I'm trying to calculate the Nusselt Number for which I need the bulk temperature.
Thanks!!
Ram
Scram_1 is offline   Reply With Quote
Old   December 31, 2023, 04:26
Goind Sharma
govind_IITD is on a distinguished road
I am using openfoam v10, trying to find Nusselt number. As far I explore it, I found that its now momentumTranportModel class which encompasses laminar and turbulent models.
I am trying to figure out how do I setup my calculation, but finding difficult.
fvc::interpolate
turbulence.valid()
? turbulence->alphaEff()()
: thermo->alpha()
) * fvc::snGrad(h)
Can someone tell, how do I modify this code for openfoam v 10?
Regards,
Govind
govind_IITD is offline   Reply With Quote
Old   December 31, 2023, 04:30
Goind Sharma
Hello Gautam,
can you please explain me:
fvc::interpolate(RASModel->alphaEff())*fvc::snGrad(h).
My understanding is "h" stands for heat-flux.
But from heat transfer calculation,
q (heat-flux) = -k_eff * grad(T)
Its somewhat confusing me, can you please clear me?
Regards,
Govind
Old   December 31, 2023, 05:56
Domenico Lahaye
dlahaye is on a distinguished road
h is enthalpy, see e.g. https://en.wikipedia.org/wiki/Enthalpy
k_eff īs the sum of laminar and turbulent (therefore total) thermal conductivity, see e.g. Turbulent thermal conductivity
dlahaye is offline   Reply With Quote
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
