Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
forces in interFoam
Old   October 21, 2011, 07:55
Default forces in interFoam
Alexander
Svensson is on a distinguished road
Send a message via Skype™ to Svensson
Hello all!
I have some problems to get forces with standard library libforces.so for interFoam solver. I found one article from workshop, in which author made own library (libhullForce.so)(http://www.openfoamworkshop.org/6th_...m/training.htm) to calculate forces in two-phase liquid. I took his case with BC, controlDict, fvSchemes and fvSolution and changed only geometry. But result that i got is not correct. Forces are greater that in experimet about 5-8 times. I saw my controlDict and found that in below entry
forces
type forces;
functionObjectLibs ("libforces.so");
patches (hull_wall);
rhoName rhoInf;
rhoInf 1000;
CofR (0 0 0);
outputControl timeStep;
outputInterval 1;
there is only one density - rhoInf equals to 1000. Can libforces.so calculate forces only for monophase liquids? I use openFoam 2.0.0. Is my guess true? How is it possible to get forces components manually?
Svensson is offline   Reply With Quote
Old   April 14, 2012, 07:02
bojiezhang
bojiezhang is on a distinguished road
Hello Svensson:
I face the same problem as you. Have you found a satisfied way to calculate the force in the two-phase flow? Could you give me some advice?
Thank you!
bojiezhang
bojiezhang is offline   Reply With Quote
Old   May 9, 2012, 13:31
Dave
daveatstyacht is on a distinguished road
Svensson,
Currently you are setting the rho equal to rhoInf for all force calcs. Use "rhoName rho;" since this is the scalar field that varies in space with alpha.
Hope this helps,
Dave
daveatstyacht is offline   Reply With Quote
forces, interfoam
Wall forces in interFoam Terp OpenFOAM Running, Solving & CFD 14 April 11, 2017 10:11
how to get forces on Iso-Clip Surfaces and How to get forces in cylindrical coordinat CFD XUE FLUENT 3 March 18, 2015 03:28
FORCES don't run! C12Carbon OpenFOAM 0 September 10, 2011 07:34
Strange results from interFoam solution converges but sum of all forces not equal to zero nicasch OpenFOAM Running, Solving & CFD 0 April 15, 2008 02:01
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 14:09
