Defining boundary conditions STL file
Old   April 19, 2012, 08:15
Default Defining boundary conditions STL file
marco100 is on a distinguished road
Since I just started exploring OpenFOAM I have a basic question.
I want to make a simulation of the air distribution in a building. I have the geometry available in an STL file (the building is drawn with AutoCAD). The STL file consists of one single block (containing the building, i.e. the walls, floor and ceiling). Inside it is open and this is the space where of course the air distribution has to be calculated.
So in the STL file there isn't any boundary condition prescribed yet (for instance there isn't an opening in a wall where air from outside can come in, the opening is something I have to create).
How can I define such an opening and get the geometry running in OpenFOAM? I have been playing with Salome and Engrid but it is not clear to me. It seems I cannot make any changes to the STL geometry.
I hope my question is clear.
Best regards,
Marco
marco100 is offline   Reply With Quote
Old   April 19, 2012, 08:33
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
I would usually separate some of the triangles of your stl to a different stl file, give the latter a different name and use it to set a boundary condition on it.
lovecraft22 is offline   Reply With Quote
Old   April 19, 2012, 08:40
Thanks for your reply.
So Openfoam can read in multiple STL files?
What would be the best pre-processor to make the separation? It seems some triangles are really big, maybe bigger than the opening I want to create. Do you have an idea for this?
Old   April 19, 2012, 08:43
lore
Yes, it can read multiple stl or even a stl with multiple regions in it.
About your problem, there are specific softwares that can do what you ask, but probably in your case the easiest way would be that of using a cad, cut the hole and save the file as building.stl, then generate a surface to cover your hole and save it as inlet.stl (or whatever you'd like). Any cad can do that.
Old   April 19, 2012, 09:01
I dont have a lot of experience with CAD programs. I only have the STL file. Can I read that in into a CAD program and make the changes you suggest?
Old   April 19, 2012, 09:06
lore
Yes, any cad software can do that.
Old   April 19, 2012, 09:28
I have AutoCAD but it cannot open STL files, only export it in that format.
Old   May 23, 2012, 08:06
Elvis
elvis will become famous soon enough
you might take a look at Blender
For an older Blender versions there are even OpenFoam related Tutorials
http://openfoamwiki.net/index.php/Tut_andrew_blender
nice thread here
http://www.cfd-online.com/Forums/ope...cii-stlbs.html
http://en.wikibooks.org/wiki/Blender_3D:_Noob_to_Pro for different Blender tasks
elvis is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
