Open Foam. BC Wedge, realizable k-epsilon, axy-simmetric
Old   May 2, 2012, 07:47
Default Open Foam. BC Wedge, realizable k-epsilon, axy-simmetric
CRT
Carles
CRT is on a distinguished road
I´m new in OpenFoam. I have to simulate an axi-symmetric geometry, so i´m using the Wedge BC. I wanted to know if i can define the BC of the wedge surface as a wedge for all the BC files (U, p, epsilon, nut, ... ). or should I set it with values like "fixed values" ..? I mean, could the program understand what a wedge BC means or not?
And someone know a Tutorials that run the realizable K-epsilon model? or someone with Axi-symmetric geometry?
Thanks a lot,
CRT is offline   Reply With Quote
axisymmetric, boundaries condition, open foam, wedge
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
