Select cells based on fields
Like Tree1Likes
  • 1 Post By dmoroian
Old   May 21, 2012, 05:31
Default Select cells based on fields
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
I'm trying to select a set of cells based on their velocity magnitude. In the old days there was an utility called fieldToCellSet, then cellSet, but now only setSet.
Could anyone clue me how to use it to select a set of cells based on their velocity magnitude?
Thanks,
Dragos
dmoroian is offline   Reply With Quote
Old   May 21, 2012, 08:15
Default setSet
dmoroian's Avatar
Dragos
The answer seems to be:
setSet
>cellSet bubu new
>cellSet bubu add fieldToCell U 50 150
>quit
Now, there is a cell set with all the cells having the velocity magnitude in the range [50;150]
sharonyue likes this.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Fluent: Mesh Adaption based on Gradient enigma FLUENT 4 July 15, 2010 17:36
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
Number of cells Christian Holm Main CFD Forum 8 February 20, 2002 07:37
