Error decomposePar
Old   May 21, 2012, 07:32
Question Error decomposePar
Lucio Cardillo
look86 is on a distinguished road
Hello Foamers,
I'm trying to decompose a very large Mesh in 96 subdomains but running the decomposePar utility I get this error after a while..
--> FOAM FATAL ERROR:
Not implemented
    From function slicedFvPatchField<Type>::slicedFvPatchField(const Field<Type>&, const dictionary&)
    in file fields/fvPatchFields/basic/sliced/slicedFvPatchField.C at line 95.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/lib/linux64Gcc44DPOpt/libOpenFOAM.so"
#1  Foam::error::abort() in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/lib/linux64Gcc44DPOpt/libOpenFOAM.so"
#2  Foam::slicedFvPatchField<Foam::Vector<double> >::slicedFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/lib/linux64Gcc44DPOpt/libfiniteVolume.so"
#3  Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::slicedFvPatchField<Foam::Vector<double> > >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/lib/linux64Gcc44DPOpt/libfiniteVolume.so"
#4  Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64Gcc44DPOpt/decomposePar"
#5  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64Gcc44DPOpt/decomposePar"
#6  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::dictionary const&) in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64Gcc44DPOpt/decomposePar"
#7  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64Gcc44DPOpt/decomposePar"
#8  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64Gcc44DPOpt/decomposePar"
#9  void Foam::readFields<domainDecomposition, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >(domainDecomposition const&, Foam::IOobjectList const&, Foam::PtrList<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >&) in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64Gcc44DPOpt/decomposePar"
#10  main in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64Gcc44DPOpt/decomposePar"
#11  __libc_start_main in "/lib64/libc.so.6"
#12  Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/afs/.enea.it/project/neptunius/soft/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64Gcc44DPOpt/decomposePar"
I don't understand why it calls the slicedFvPatchField<type> 'cause I don't have this PatchField in any of my boundary fields..
I'm using only zeroGradient, timeVaryingMappedFixedValue, wall and cyclic boundary condition.
best regards,
Lucio
look86 is offline   Reply With Quote
Old   May 28, 2012, 03:44
kid
cfdkid
kid is on a distinguished road
Did you run blockMesh before decomposePar.
Try deleting all files except blockMeshDict from /constant/polyMesh/.
And run the commands again.
EDIT:
Note: If you are using snappyHexMesh use below command only.
snappyHexMesh -overwrite
Good luck
________________________________________
Regards,
CFDkid
It never gets easier You just get Better
kid is offline   Reply With Quote
Old   May 30, 2012, 07:17
Lucio Cardillo
thank you for the reply!
However I resolved by replacing the time start directory with a older backup copy and it works fine
I originally supposed that the error came from a cellSet I created to make postprocessing more friendly, but the problem probably was in fields stored in that directory..
regards,
Lucio
