How to create a axis of symmetrie with Salome?
Old   July 7, 2012, 07:16
Default How to create an axis of symmetrie with Salome?
Mark
mc monti is on a distinguished road
I try to create an axis symmetric mesh with salome, but I don't know how to export the axis of symmetrie. I created a group of edges but as soon I start converting it with ideasUnvToFoam I get an error message.
From function HashTable<T, Key, Hash>::operator[](const Key&)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/HashTableI.H at line 117.
FOAM exiting
If I remove the group in salome I can convert it without problems. But then I don't have an axis anymore. I did read the article in OpenFoam Wiki, but their is always expected that the conversion went alright.
Can somebody help me?
mc monti is offline   Reply With Quote
Old   July 7, 2012, 18:24
Assistant Moderator
Bernhard Gschaider
FOAM exiting
With axisymmetric you mean "In the OpenFAM-sense: a one cell thick wedge"? Not 100% sure, but I think that the converter has a bit of a problem with the wedge-cells at the axis.
In the past I found it easier to create a one cell thick 2D-mesh and let http://openfoamwiki.net/index.php/Contrib_MakeAxialMesh do the conversion to a wedge. But I'm not completely objective here
[blockMesh] Create a "triangular box" with blockMesh voingiappone OpenFOAM Meshing & Mesh Conversion 4 May 22, 2015 02:22
[DesignModeler] How to create smaller pipe inside bigger pipe? Munggang ANSYS Meshing & Geometry 2 March 7, 2012 14:01
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 08:59
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
