Creating nonOrtho faceSet
Old   August 7, 2012, 11:52
Default Creating nonOrtho faceSet
alf12 is on a distinguished road
Dear readers,
I would like to extract faces from a mesh for which orthogonality is above a given value. This is exactly what is done by checkMesh but I want to set the non orthogonality input.
I have had a look at the setSet utility but I didn't manage to do that. Neither I have found a way to change checkMesh behavior.
How can I [simply] do that ?
Thanks
alf12 is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
[swak4Foam] Mass flow rate through faceSet using swak4foam CedricVH OpenFOAM Community Contributions 5 May 4, 2012 07:57
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
[mesh manipulation] creating faceSet ganeshv OpenFOAM Meshing & Mesh Conversion 1 June 15, 2011 09:13
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 03:02
