Using Surface Solution Data as Boundary Condition
Old   August 30, 2012, 09:46
Default Using Surface Solution Data as Boundary Condition
matari is on a distinguished road
I have a mesh with two different cell zones. In each cell zone I want to solve different chemical reactions with rhoReactingFoam. The interface between the two cell zones is a
wall with a temperature field that depends on the chemical reactions in both cell zones. I thought about solving this problem in an iterative process, where one cell
zone is calculated at first and the temperature field at the interface is used as boundary condition for the calculation of the other cell zone. How can I write the temperature data
that is calculated in the first cell zone at the interface into a file to use it as boundary condition for the calculation of the second cell zone? I'm using OpenFOAM-2.1.x.
Thanks in advance for any hint,
Matari
matari is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Use sampled data from previous run as boundary condition for new setup Arnoldinho OpenFOAM Running, Solving & CFD 3 December 6, 2012 13:16
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
Boundary condition for periodic flow solution in Gambit ghmahtabi Main CFD Forum 2 March 20, 2012 16:22
how to provide accurate inlet boundary condition from experimental data? swe704 FLUENT 0 September 29, 2009 04:01
