Rotor-Stator with separate imported meshes
Old   October 26, 2012, 04:38
Default Rotor-Stator with separate imported meshes
Anon
jrrygg is on a distinguished road
I am currently working on simulating the flow in a Pelton turbine, and have already created and run a simulation in Ansys CFX. I aim to convert this to an OpenFOAM case to be able to compare the quality of the results.
I am not that experienced with OpenFOAM, at least not with this type of complex case, and I hope to get some tips on how to approach this.
First of all, is this doable, or am I aiming to high?
I believe the solver I should use is pimpleDyMFoam. I am struggling to see how I can combine my two meshes (stationary and rotating) in OpenFOAM.
Short description of setup:
-Stationary mesh, imported from Ansys. Domain and water inlet (jet)
-Rotating mesh (should I import this to the same folder case?). Consisting of domain and three buckets.
-Both meshes have a sliding interface.
-Rotating mesh should only rotate enough so that all three buckets have had a fully developed jet (<180 degrees)
Update:
I got the mesh merged by mergeMeshes and it looks fine. However, as I will have a two-phase flow (water jet and air in the same domain) I will probably have to use another solver. I'm guessing interDyMFoam might do the trick?
jrrygg is offline   Reply With Quote
Old   October 27, 2012, 07:55
Hrvoje Jasak
Just saw your post - mergeMeshes is the correct answer.
Hrv
Hrvoje Jasak
Old   October 29, 2012, 07:04
Anon
Thank you for your reply!
Any idea regarding which solver I should use? The case is multiphase, moving mesh and transient.
Regards,
Jone
Old   October 29, 2012, 09:01
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
you guessed right, interDyMFoam is waht you are looking for.
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   October 29, 2012, 09:42
Anon
Thank you very much!
pimpledymfoam, rotor-stator
[ICEM] Merging Hexa Meshes in ICEM screech1987 ANSYS Meshing & Geometry 11 March 13, 2014 11:45
GGI interpolation between separate meshes (regions) cliffoi OpenFOAM Programming & Development 0 June 27, 2011 11:59
[Netgen] keeping/changing dimensions in imported meshes bigred OpenFOAM Meshing & Mesh Conversion 2 September 28, 2009 03:38
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 15:49
[Technical] Using stitchmesh on imported gmsh meshes christian67 OpenFOAM Meshing & Mesh Conversion 0 November 26, 2005 04:22
