setfields utility for liquid jet
Old   March 7, 2013, 09:50
Question setfields utility for liquid jet
sandy
sandy13 is on a distinguished road
Dear foamers,
Pleaes can any body direct me. I am trying to solve a jet flow problem by using interFoam solver. I have a cuboid and I suppose to implement a jet from above moving dowen along the z-direction. x=0.001,y=0.001,z=0.12...jet diameter=0.0004. I have all the boundaries are walls just the above and lower sides are atmosphere. Can I use setfields utility to implement the liquid phase inside my region and what kind of word code for the shape? is it plaintocell or circuletocell like boxtocell as an example, because I have to start from above in a circle cross section shape with a specific velocity. please any thoughts or advice would help so much.
sandy13 is offline   Reply With Quote
Old   March 8, 2013, 11:06
Davide D.
dav.dap83 is on a distinguished road
A possible idea:
1) Divide the top boundary into two patches, i.e. one free and one for the jet (above circle).
2) Set Ugas fixedvalue uniform (0 0 0) and Uliquid fixedvalue uniform <your jet velocity> for the jet patch.
3) alpha = <gas value> for the whole domain. No setfields needed.
dav.dap83 is offline   Reply With Quote
Old   March 11, 2013, 11:10
sandy
Originally Posted by dav.dap83 View Post
A possible idea:
Dear dav.dap83,
Thank you for your help, I did as you recommended but I faced this error:
FOAM FATAL IO ERROR:
keyword inlet is undefined in dictionary "/home/atheel/interFoamvalidation/laminar/liquidjetinjector/0/p_rgh::boundaryField"
I already defined inlet but I do not what is the problem.. you can take a look below at my p_rgh; , U , alpha1 , alpha. and I wish if you can help me...
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
leftWall
type buoyantPressure;
value uniform 0;
rightWall
value uniform 0;
upperWall
value uniform 0;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
// atmosphere
// type totalPressure;
// p0 uniform 0;
// U U;
// phi phi;
// rho rho;
// psi none;
// gamma 1;
// value uniform 0;
inlet
type zeroGradient;
// type buoyantPressure;
// value uniform 0;
frontWall
value uniform 0;
backWall
value uniform 0;
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
leftWall
type fixedValue;
value uniform (0 0 0);
rightWall
type fixedValue;
frontWall
type fixedValue;
backWall
type fixedValue;
upperWall
type fixedValue;
inlet
type fixedValue;
value uniform (0 0 -3);
atmosphere
type pressureInletOutletVelocity;
FoamFile
version 2.0;
format ascii;
object alpha;
dimensions [0 0 0 0 0 0 0];
boundaryField
leftWall
type zeroGradient;
rightWall
type zeroGradient;
inlet
type fixedValue;
value uniform 1
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
// atmosphere
// type zeroGradient;
frontWall
type zeroGradient;
backWall
type zeroGradient;
upperWall
type zeroGradient;
FoamFile
version 2.0;
format ascii;
object alpha;
boundaryField
leftWall
type zeroGradient;
rightWall
type zeroGradient;
upperWall
type zeroGradient;
inlet
type zeroGradient;
atmosphere
type inletOutlet;
value uniform 0;
// atmosphere
frontWall
type zeroGradient;
backWall
type zeroGradient;
Sandy,
Old   March 11, 2013, 11:14
Davide D.
you forgot to close the parenthesis } in p_rgh after upperWall
Old   March 11, 2013, 12:02
sandy
Dear dav.dap83,
Thank you so much, I am so embarrassed, any how I fixed this error but still get another error and I do not why? the error is:
--> FOAM FATAL IO ERROR:
keyword atmosphere is undefined in dictionary "/home/atheel/interFoamvalidation/laminar/liquidjetinjector/0/alpha1::boundaryField"
file: /home/atheel/interFoamvalidation/laminar/liquidjetinjector/0/alpha1::boundaryField from line 25 to line 64.
If you take a look at my dictionary, I defined atmosphere...
Sandy,
Old   March 12, 2013, 06:14
sandy
Originally Posted by sandy13 View Post
Dear dav.dap83,
Sandy,
Dear dav.dap83,
Sorry for being obtrusive, but I wanted to ask you, do I need to use topoSetDict like in the nozzleFlow2d tutorial?. I do not what to do, I tried to fix the last error but still get the same one:
Sandy,
Old   March 17, 2013, 09:05
Michiel
michielm is on a distinguished road
Dear dav.dap83,
Sandy,
There is a \ before the closing } of atmosphere in the first dump of alpha you show (why do you have two in your post?!)
michielm is offline   Reply With Quote
Old   April 4, 2013, 08:50
Default no convergence for the liquid jet case
sandy
Dear michielm,
I am still struggling in my case, I ran my case finally but with out any convergence, I do not know, I used delta T =0.001, Co=0.5 in my control dict., Is that too bad? Or may be because of bad boundary conditions. Would you please help me which is the best boundary condition for a liquid jet and here is my final set of my boundary conditions...
in this link, please have alook at it when ever you have time.
note: 1- I am using interFoam utility for OF 2.1.1.
2- for geometry I used blender to get STL ascii in order to use snappy for my mesh
https://www.dropbox.com/home/openfoam-shear
Old   April 4, 2013, 11:18
Michiel
Hi Sandy,
I cannot read the dropbox folder because you posted the wrong link (you need to click the 'share link' button of the folder and then 'get link' and copy paste that one in your post)
Just a thought: your deltaT seems high but I cannot judge without details of your mesh and velocities. Co=0.5 is a bit high for interFoam, but should at least give convergent results. Did you set 'adjustTimestep' to 'yes'?! Or is your case running by your deltaT?
Old   April 4, 2013, 11:52
sandy
Hi Sandy,
Dear michielm,
Thank you so much for your replay, I feel so happy when somebody shares me thoughts about OpenFoam because I feel so lonely in this field. Yes I set 'adjustTimestep' to 'yes. Sorry about this little mistake and this is the link for all of my case:
https://www.dropbox.com/sh/ilvn6y9mlkgl3gs/AWqK6vZU4h
Hopefully this time works, If it did not let me know because I am a noob in dropbox as well.
sandy,
Old   April 9, 2013, 04:53
  #11
sandy
Dear michielm,
sandy,
Dear michielm,
I sent you may case couple days ago, please have a look at it, I have checked every thing, but still I do not get any convergence, may be you will know why. I think it is the boundary conditions but I do not which boundary?...
Sandy,
Old   January 1, 2019, 00:57
Smile
  #12
Vivek
vivek05 is on a distinguished road
Dear michielm,
Sandy,
Hi Sandy,
It has been around five years after the last post in this thread.
have you found a solution to this problem? Because I am also working on the same topic. Could you share your findings related to this topic?
Thanks!!!
vivek05 is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
2D Plane Jet Fluent Solution doug Main CFD Forum 11 February 4, 2019 09:34
Problems with the execution of the setFields utility. foamer OpenFOAM Pre-Processing 5 June 3, 2013 12:24
Jet in Supersonic Crossflow, controlling mass flow rate ChrisA OpenFOAM Running, Solving & CFD 3 November 13, 2012 18:20
IMPINGING JET ........... HELP!!!!!!!! Amir Omoumi Main CFD Forum 10 August 30, 1999 22:11
