April 12, 2013, 09:19 |
Problem with Rosin Rammler
#1 | |
Rep Power: 16 |
Hi all,
I want to use a RosinRammler pdf for my parcels. In the the source code I found the following: Quote:
I callculated K and with that later the x value. For y I take a list of 100 values from 0 to 1. Then I thought for y= 0.5 I should get the value for dv50 of my destribution. The same I did with y= 0.9 for dv90. But the distribution in FOAM later on does not correspond to my excel values. What is the error that I do? Thanks for you help in advance. Kind regards Chrisi |
February 24, 2021, 11:53 |
Adithya Gurumurthy
Rep Power: 9 |
Hi Chrisi, did you figure this out?
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
