Problem with Rosin Rammler
Old   April 12, 2013, 09:19
Default Problem with Rosin Rammler
Chrisi1984 is on a distinguished road
I want to use a RosinRammler pdf for my parcels.
In the the source code I found the following:
Foam::scalar Foam::distributionModels::RosinRammler::sample() const
scalar K = 1.0 - exp(-pow((maxValue_ - minValue_)/d_, n_));
scalar y = rndGen_.sample01<scalar>();
scalar x = minValue_ + d_*:ow(-log(1.0 - y*K), 1.0/n_);
return x;
I tried to implement exactly that in excel to calculate the values for minValue, maxValue, d and n for my desired distribution.
I callculated K and with that later the x value. For y I take a list of 100 values from 0 to 1.
Then I thought for y= 0.5 I should get the value for dv50 of my destribution. The same I did with y= 0.9 for dv90.
But the distribution in FOAM later on does not correspond to my excel values.
What is the error that I do?
Thanks for you help in advance.
Kind regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   February 24, 2021, 11:53
Adithya Gurumurthy
raptorishungry is on a distinguished road
Hi Chrisi, did you figure this out?
raptorishungry is offline   Reply With Quote
[Other] engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 08:45
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
