MapFields seems hanging
Old   April 23, 2013, 10:28
Default MapFields seems hanging
Fire2fly is on a distinguished road
For a grid convergence study I am trying to map the fields from a coarse mesh to a finer mesh with MapFields. MapFields seems however hanging at the statement:
Create databases as time
Source time: 0
Target time: 0
Create meshes
Source mesh size: 366539         Target mesh size: 461702
Both -consistent and with a mapFieldsDict file does not work. The patches for both cases are exactly the same, except for one patch that is generated by snappyHexMesh which could locally be a little bit different. Could that be a problem?
Fire2fly is offline   Reply With Quote
Old   May 3, 2013, 05:45
hannes
hanness is on a distinguished road
I came across the same problem and was able to narrow it down a little bit. Using blockMesh as mesh generator everything works fine as long as only orthogonal cells are refined. Moreover, as long as I refine the mesh along the direction of one of the coordinate axes everything is fine also for nonorthogonal cells. However, I've got cells in the boundary layer with very high aspect ratios (~600) and I would like to refine the mesh in the direction of the wall (which is inclined) and that does not work anymore.
I also tried to use mapFields with the option -mapMethod mapNearest in order to overcome any potential problem with the interpolation but it still does not work.
Anybody any idea?
Best regards
Hannes
hanness is offline   Reply With Quote
Old   June 2, 2014, 17:19
Jason Pearl
jaason is on a distinguished road
I've been having issues with OF230 mapfields command as well,
it meshes and the fields look absolutes fine but I end up getting errors when I run the solver,
are you saying that your will not even finish the mapfields proceedure?
jaason is offline   Reply With Quote
Issues with mapFields BlackBoatNavArch OpenFOAM Pre-Processing 38 May 28, 2021 16:29
implementation of mapFields into parallel transient case simpomann OpenFOAM Pre-Processing 4 August 2, 2016 04:41
mapFields doesn't change fields Werne OpenFOAM 6 July 30, 2016 12:45
mapFields problem martyn88 OpenFOAM 1 November 8, 2012 13:42
transientSimpleDyMFoam, mapFields and decomposePar pad OpenFOAM Running, Solving & CFD 0 December 3, 2010 05:22
