Can compressibleTwoPhasesEulerFoam calculate two miscible Gases with each other?
Old   October 10, 2013, 10:32
Default Can compressibleTwoPhasesEulerFoam calculate two miscible Gases with each other?
Kenna is on a distinguished road
Can compressibleTwoPhasesEulerrFoam calculate two miscible Gases with each other?
I am simulating a case with air and argon. I chose the compressibleTwoPhasesInterFoam solver because I need the the the temperature calculated. So far I am getting results far away from what they should be. Before I invest any more energy in searching an error I need to know: Is the compressibleTwoPhasesInterFoam able to calculate two miscible Gases with each other? No dispersion, no drag, just two gases.
compressibleTwoPhasesEulerFoam is not mentioned in the UserGuide.
Regards Kenna
Kenna is offline   Reply With Quote
eulerian multiphase model, solver, solver documentation
2D simulation for mixing two non-reacting gases arun.mechie FLUENT 17 August 3, 2016 08:31
calculate species reaction rate Anna_p FLUENT 2 July 1, 2013 13:10
calculate values for eps and k from Re or u????? sbar OpenFOAM Pre-Processing 5 August 16, 2010 04:10
How to calculate Torque for francis turbine manish CFX 4 March 15, 2007 02:57
can use coupled solver to calculate combustion cfdfans FLUENT 0 November 25, 2003 04:48
