external wall heat transfer
Like Tree1Likes
  • 1 Post By olivierG
Old   January 23, 2014, 03:17
Default external wall heat transfer
ashwin
ashghan is on a distinguished road
I am actually trying to implement a boundary condition with heat transfer through the external wall. The equation is
Tw=(Tair-(alphain+(l/d)+alphaout)(Tair-Tinf))/alphain
 where Tw = wall temperature
 Tair = air temperature (calculated from the solver)
 alphain = heat transfer coefficient on the inside of the wall( calculated from the solver)
 l= thermal conductivity;
 d= virtual wall thickness;
 alphaout=heat transfer coefficient on the outside of the wall
 Tinf= outside temperatue
Has anybody got any idea on how to implement this BC using groovy? with alphain and Tair generating from the solver. Till now I have tried something like this:
wand2
        type groovyBC;
        value uniform 293.15;
       fractionExpression "0";
       variables "alphaa=20;Tinf=300;d=0.015;l=23;Tw=(Tair-(alphain+(l/d)+alphaout)(Tair-Tinf))/alphain";
                    timelines (
which does'nt work and gives me an error like this
--> FOAM FATAL ERROR:
 Parser Error for driver PatchValueExpressionDriver at "1.30" :"syntax error, unexpected '('"
"(Tair-(alphaa+(l/d)+alphaout)(Tair-Tinf))/alphaa"
Context of the error:
- From dictionary: /home/ashwin/Desktop/wallbc/0/T.boundaryField.wand2
  Evaluating expression "(Tair-(alphaa+(l/d)+alphaout)(Tair-Tinf))/alphaa"
    From function parsingValue
    in file lnInclude/CommonValueExpressionDriverI.H at line 1081.
FOAM exiting
I am using buoyantSimpleFoam Solver. I have no idea on how to generate the Tair and heat transfer coefficient from the solver.
I hope somebody here has an idea about it.
Regards
Ashwin
Last edited by ashghan; January 24, 2014 at 05:07. Reason: checked on how to post a thread :)
ashghan is offline   Reply With Quote
Old   January 29, 2014, 06:52
Tobi's Avatar
Tobias Holzmann
Hi Ashwin,
hmmm your problem seems "easy".
First - the solver calculates Alpha (in the air Domain) and you will get the temperature of the wall.
You want to extend the wall with an thickness of "l" to simulate a pipe or sth like that and the heat Transfer from the pipe to the outer fluid (i think air).
So you will do a fluid - solid - fluid Simulation.
a) you can do it with chtMultiRegion
b) you can build your own BC - as you tried
In your case (b) you made some mistakes.
1. you do not calculate the heat Transfer from fluid to solid surface - that do the solver. Therefor you do not Need alphain.
2. Tair is not a OpenFOAM variable. I think you have to use "T" or "T()" instead.
3. I did not get your Point with Tw, Tair, Tinf. What do you want to achive? In my opinion you Need:
- conductivity
- Tinf
- Thickness
Any questions?
Regards Tobi
Old   January 29, 2014, 07:04
ashwin
Hello Tobias,
First of All, Thank you for the reply.
Yeah I need conductivity, Thickness, The outside wall temperature = Tinf and the heat transfer coefficient on the outside = alphaout as a user input to calculate the Tw= wall temperature on the inside.
I am applying this to a Normal wall(with a thickness d) in a room, to calculate the inside wall temperature.
Regards
Ashwin
Old   January 29, 2014, 07:29
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
I think you're trying to apply a mixedBC / Robin boundary condition: http://www.cfd-online.com/Forums/ope...acianfoam.html
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   January 29, 2014, 09:45
ashwin
I am trying to do something similar to the external wall heat flux.
Regards
Ashwin
Old   January 29, 2014, 15:09
Tobi's Avatar
Tobias Holzmann
Hi Ashwin,
ähm ... hmmm i am a bit confused
Just to clear my mind. You want to bring heat energy into your system ?
Well alphaout you have to define yourself
Old   January 29, 2014, 16:23
ashwin
Hello Tobias,
Yes I am bringing the heat Energy from outside the system and yeah I give alphaout, conductivity, thickness and outside temperature as a user input.
The alphain and Tair are derived from the solver. So when I use a Value expression like
Tw=(T-(alpha+(l/d)+alphaout)(T-Tinf))/alpha
It does'nt work. So how do I calculate the Tw?
http://www.flickr.com/photos/115947529@N08/12211738076/
Old   January 29, 2014, 17:03
Tobi's Avatar
Tobias Holzmann
Originally Posted by ashghan View Post
Hello Tobias,
Hi you have a logical mistake.
You do not need Tw ... Tw is calculated from the solver!
Regards
Tobi
Old   January 30, 2014, 03:43
ashwin
Regards
Tobi
Now I am using this piece of code
wand2
                 type groovyBC;
                 variables "alphaout=20;Tinf=300;d=0.05;l=0.05;";
                 Value Expression "(T-(alpha+(l/d)+alphaout)*(T-Tinf))/alpha";
                 timelines       ();
and I get the following error
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::incompressiblePerfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:?
#4  Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::incompressiblePerfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:?
 at ??:?
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
Floating point exception (core dumped)
Any ideas on this?
Regards
Ashwin
Old   January 30, 2014, 04:45
Olivier
olivierG is on a distinguished road
hello,
Why you don't use the "externalWallHeatFluxTemperature" BC ?
regards,
olivier
olivierG is offline   Reply With Quote
Old   January 30, 2014, 04:49
ashwin
Originally Posted by olivierG View Post
hello,
regards,
olivier
I tried to use that, but I am not getting good heat balance. The HeatFlux's seem to be bad.
Regards
Ashwin
Old   January 30, 2014, 05:18
Olivier
hello,
If something is wrong with "externealWallHeatFluxTemperature", you may report as a bug. This will help all OF user, including you.
If you use use groovyBC, you may follow the advice from Akidess:
type groovyBC;
variables "alphaout=20;Tinf=300;d=0.05;l=0.05;alphawall=l/d;K=DT*rho*Cp;htot=alphaout+alphawall;";
valueExpression "Tinf";
fractionExpression "1.0/(1.0 + K/(mag(delta())*htot))";
NB: you need to adapt the conductivity "DT" name, density "rho" and "Cp" name.
regards,
olivier
Old   January 30, 2014, 05:34
ashwin
Hello Oliver,
I have a question from your code.
Why do we need DT and K ? Since l is the thermal conductivity provided.
Regards
Ashwin
Old   January 30, 2014, 05:45
Olivier
Check and read the link from Akidess for more info.
DT, rho , Cp are for the bulk properties.
regards,
olivier
akidess likes this.
Old   January 30, 2014, 10:11
ashwin
Hello Tobias, Akidess and Oliver,
I have another question regarding external wall heat flux temperature. Can I input Q in [W/m³] instead of [W/m²] making it as a volumetric source term?
Regards
Ashwin
Old   January 31, 2014, 09:17
ashwin
My Expression is working when I use h instead of alpha. Is it correct? I took it as h w.r.t to convective heat transfer coefficient notation. Please leme know if I am wrong.
valueExpression "(T-(h+(l/d)+alphaout)*(T-Tinf))/h";
If I use alpha I get an error saying
Parser Error for driver PatchValueExpressionDriver at "1.5-9" :"field alpha not existing or of wrong type"
Regards
Ashwin
Old   October 27, 2015, 20:29
nasir musa yakubu
esujby is on a distinguished road
I am currently trying to model a solar volumetric receiver, i have conducted optical ray tracing analysis and have value for the heat flux at the aperture of the receiver. i have the data for the heat flux in 3 formats, grid form, matrix form, and table form. the heat flux represents a spot focus area (3cm radius) with energy density values in the formats mentioned. if you can shed some light on this issue it would be really helpful.
thanks
esujby is offline   Reply With Quote
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Radiation interface hinca CFX 15 January 26, 2014 17:11
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
WALL HEAT TRANSFER COEF...AGAIN Carl CFX 2 July 8, 2005 01:35
