February 21, 2014, 10:37 |
Free convection
Michael Leck
Rep Power: 12 |
Hey guys,
I try to simulate a verticale plate in the atmosphere. For this case I create a box and on one side I add a small plate. Around I want to have everywhere atmosphere (air). The plate should have an temperature from 333 K and the atmosphere should have 293 K. However I get always worst results. I think my boundarys are wrong. Have somebody fixed this issue and can sent me a example case or tell me the right boundarys in the T, U, p_rgh and P file for my plate and the atmosphere? regards Michael |
March 6, 2014, 05:08 |
Please furnish more details
Sushanta Sahu
Can you please furnish more details like what is the element size, number, layers, etc?
March 6, 2014, 06:31 |
Michael Leck
Rep Power: 12 |
Hello sengerandu,
thank you for your reply. My first cell ist 0,014 mm thick and the gradient ist 20. Now I've changed my case. I have a horizontal zylinder. In the vertical I used a symmetrPlane to reduce my mesh. Also I simulate 2D now. T-File: Is on atmosphere "inletOutlet" and on the wall ist "fixedValue". U-File: For atmosphere I use "pressureInletOutletVelocity" and for the wall I use "fixedValue". P-File ist "calculated" I think there ist a problem with the p_rgh file. Here I tried a lot of values: fixedValue, fixedFluxPressure, zeroGradient, totalPressure for the wall and atmosphere. And my flow pattern look like worse! Best wishes Michael |
March 10, 2014, 10:35 |
Rep Power: 12 |
Micha69822,
¿did you get your case runnin? You are trying to simulate an open environment aren´t you? So am I, but I dont get any physical results.... It must be the boundary conditions... Cristina |
March 10, 2014, 13:35 |
Michael Leck
Rep Power: 12 |
yes I did. My failure was the p_rgh File. The bottom has to defined as "totalPressure" and the atmosphere around has to "inletOutlet". The other BC's the same as I described. And now I get the right solutions!
Best regards Michael |
March 11, 2014, 05:58 |
Rep Power: 12 |
Hi Micha69822,
Which solver are you using? buoyantBoussinesqSimpleFoam? I am trying with SimpleFoam, but I do not find the right BC. I have flow over a ground in atmospheric conditions.... very simple: inlet (constant wind velocity) outlet, sides and Sky and then the ground.... As you recommended, I am using totalPressure in the outet but I dont get good results... Can you post your BC more detailed? I also attach you my case, maybe you can help me... thanks! Cristina |
March 11, 2014, 07:41 |
Michael Leck
Rep Power: 12 |
Hi cristina,
I can't work with your files because I use OpenFOAM Version 2.3.0. But I see in your blockMeshDict that you have defined all faces as wall. For atmosphere you need patch but there is a different in the Versions?!
March 11, 2014, 08:27 |
Rep Power: 12 |
In effect, when I change the BC to patch it does not even run.... I dont know. Can you detail me your BC? So I can try to do the same? thank! |
March 11, 2014, 10:07 |
Michael Leck
Rep Power: 12 |
Hello cristina,
my settings in the attachment. I hope it help you? I forgot to tell you my Sovler. I use the buoyantBoussinesqSimpleFoam and the buoyantSimpleFoam.
March 12, 2014, 02:20 |
Rep Power: 12 |
Hi Micha,
¿your bottom is a wall? ¿like the ground? Cristina |
March 12, 2014, 04:55 |
#11 |
Michael Leck
Rep Power: 12 |
no. I simulate a pipe an this surface is in my case the wall.
atmosphere, natural convection |
free convection | Arun3012 | FLUENT | 0 | February 25, 2013 00:45 |
Free convection | ebrattr | COMSOL | 6 | August 20, 2012 16:05 |
CFX-5.5 simulating air free convection | Dustin Lee | CFX | 0 | April 16, 2003 02:54 |
Free Convection in STAR-CD | George Hampel | Siemens | 0 | November 15, 2000 23:38 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
