Jim
Rep Power: 12 ![]() |
I would like to use a boundary condition at an inlet that allows a pressure-time profile to be specified, which is also non-reflective. Currently I am using timeVaryingUniformFixedValue to create the pressure-time profile at the inlet, but I think I am getting reflections at the inlet. I have tried timeVaryingUniformInletOutlet which doesn't seem to help. Can anyone advise if a boundary condition exists which does this? thanks |
Daniel
Rep Power: 16 ![]() |
Hello James,
I am struggling with the same issue, though I am using a time-dependent U at the inlet. My domain consists of a C-grid with the outlet defined as the vertical section at the back, and the rest of the boundary as the inlet - similar to the tutorial nacaAirfoil. Since the angle of inflow is changing as a function of time, some of the time the inlet will be acting like an outlet. I think a new boundary condition might be required - a blend of uniformFixedValue and supersonicFreestream/waveTransmissive, perhaps? I will try to create a new BC that does this and post my results if I am successful. My C++ skills are not strong, but I will give it a shot. Regards, Dan |
Daniel
Well trying to set up a new BC is not as straightforward as I thought. Starting from the basics, I followed the instructions at the link below just to try renaming an already-existing BC:
- I copied the waveTransmissive folder into $FOAM_USER_LIBBIN - renamed all instances of "waveTransmissive" to "waveTransmissiveTimeVarying" in the files and filenames - used the attached files in the Make directory - successfully built libwaveTransmissiveTimeVarying.so Then, in the nacaAirfoil case: - added "libs ("libwaveTransmissiveTimeVarying.so");" to controlDict - changed the pressure boundary type to "waveTransmissiveTimeVarying" When I run it sonicFoam on it, though, I get the following error: Code:
--> FOAM FATAL IO ERROR: Unknown patchField type waveTransmissiveTimeVarying for patch type patch Valid patchField types are : Any ideas what could cause this? I hope to create a new BC; right now I cannot even copy and use an existing one! Note that I added the ".txt" extension to all attachments just so they could be uploaded. Link for instructions: http://openfoamwiki.net/index.php/Ho...dary_condition Thanks in advance for any assistance. Daniel |
Daniel
I made a mistake in the make/files file. Works now, will now look at combining waveTransmissive and uniformFixedValue.
Dan New make/files: Code:
$(FOAM_USER_LIBBIN)/waveTransmissiveTimeVarying/waveTransmissiveTimeVaryingFvPatchFields.C LIB = $(FOAM_USER_LIBBIN)/libwaveTransmissiveTimeVarying |
RM
Rep Power: 0 ![]() |
I know I'm a little late to ask you an answer, but now I'm just working on a similar problem. I need to have an outlet where I apply a time dependet boundary condition on pressure by a tabel, but also that allows propogation of waves, i.e. a waveTransmissive Boundary conditions where I give a table of values instead of just one fixedValue. I couldn't get very well your procedure, if you could explain to me just another time it would be very important to me (I started few weeks ago with OpenFoam ![]() Best regards. |
Daniel
Hello Alessandro, I'm afraid I was not successful in the end, but reflection did not turn out to be much of a problem in my case so I let it go. Good luck,
Daniel |
inlet and outlet pressure, non-reflecting bc |
LES inlet boundary conditions | hz283 | OpenFOAM | 17 | December 29, 2019 16:59 |
ribbed channel / simpleFoam / boundary conditions | beeo | OpenFOAM Pre-Processing | 20 | July 17, 2013 08:39 |
inlet boundary conditions | mattia | Main CFD Forum | 0 | February 11, 2009 06:06 |
reflective boundary conditions on generalized coor | buaalzr | Main CFD Forum | 3 | January 2, 2008 12:43 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 01:54 |
