initial condition for k and epsilon for frozen rotor case. |
June 6, 2014, 12:19 |
Hi all,
I'm trying to simulate a fan inside channel, using MRF source terms and simpleFoam. I'm looking for help how to calculate values of k and epsilon for a wall bounded flow of such type of case. I look into literature, but I was able to find correlation only for free-stream flows, or bounded flows with constant section. One thing I have doubt is: in my case, I have many sections for each channel, and I don't have a free stream velocity as it changes according to section's change. How can I set proper initial condition for k and epsilon? I'm a bit confused and I would like to have a little help to clarify myself. Thanks a lot. |
June 12, 2014, 05:38 |
Thomas
Rep Power: 12 |
Im not sure if my answer is what you are looking for. I think i would first calculate the values with the "ordinary" formula for k and epsilon: k=1.5*(U*I_U)^2 epsilon=(0.09^(0.75)*k^(1.5))/(L_t) L_t=L_U*L You can try to change I_U (turbulence intensity). Im sure there is a description in the wiki here as well. Regards Thomas |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
