Pressure BCs in buoyantPimpleFoam
Like Tree1Likes
  • 1 Post By jherb
Old   July 4, 2014, 14:51
Default Pressure BCs in buoyantPimpleFoam
Ian Dizon
superian is on a distinguished road
Hello FOAMers,
I am using buoyantPimpleFoam to simulate a air flow within a furnished room.
I have one inlet, one outlet, and some furniture some of which act as heat sources (computers,lights,occupants).
But I am confused when setting pressure boundary conditions at inlet,outlet and walls.
p_rgh:
internalField uniform 1e5;
for the walls/furniture:
type zeroGradient;
for inlet:
type zeroGradient;
for outlet:
type fixedValue;
value 1e5;
p:
everything else:
type calculated;
value $internalField;
U:
inlet:
type fixedValue
value uniform (0 0 0);
outlet:
type zeroGradient;
everything else (0 0 0);
Do these make sense? If not can anyone explain to me how I should set these up?
Thanks in advance,
Ian
superian is offline   Reply With Quote
Old   July 5, 2014, 18:52
Joachim Herb
jherb is on a distinguished road
Have a look at the tutorial of buoyantPimpleFoam:
https://github.com/OpenFOAM/OpenFOAM...Foam/hotRoom/0
For the pressures (p_rgh) on the walls you probably want something like fixedFluxPressure.
0 velocity for the inlet does not make sense, because then its a wall.
KDK likes this.
jherb is offline   Reply With Quote
Old   July 7, 2014, 18:04
Ian Dizon
Thanks for the reply!
You are right! My inlet should have a value.
It is actually:
type fixedValue
value uniform (0.086 0 0)
Maybe you know more about fixedFluxPressure. From what I understand is that it will calculate pressure based on the mass flow rate normal to the surface. Is this correct?
Also, can this be used as a BC for p_rgh at my inlet as well?
Calculating Pressure Drop - BCs spoon OpenFOAM Running, Solving & CFD 1 February 25, 2013 18:47
Pressure BC's for ABL modelling jgpeder OpenFOAM 1 June 9, 2010 14:33
Pressure BCs or Periodic BCs for model of frost on vertical surface? andy.eco FLUENT 2 March 26, 2010 02:02
Average static pressure BCs and aircore in cyclone KM CFX 2 December 17, 2007 20:50
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
