Internal Patch
Old   August 14, 2014, 07:47
Default Internal Patch
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
how can I create a internal patch to use it with groovyBC ?
Any hints are appreciated.
Regards
Tobi
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   August 19, 2014, 04:05
Tobi's Avatar
Tobias Holzmann
Hi all,
I created the internalFaces with createBaffles and if I use the cyclic BC everything is working fine. Now I want to close that internalFace step by step with groovyBC. At the moment I have problems because groovyBC is not compatible to the cyclic type.
Well if someone has some hints it would be recommended!
In the attachment you see a picture of the issue.
Regards
Tobi
Keep foaming,
Tobias Holzmann
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
