Parralel/Rotational velocity boundary condition on Wedge mesh
Old   August 14, 2014, 10:05
Default Parralel/Rotational velocity boundary condition on Wedge mesh
Erik
ling40 is on a distinguished road
Hello all, I've made a simple wedge type mesh with ID and OD. The ID is a shaft while the OD is the casing with a gap between the two simulating wear of the sealant.(supposed to be modeled as an annular) The shaft rotates at 371.75 rads/sec which makes the surface velocity 10.5 m/s. Flow is pressure induced, with a pressure gradient "fixedValue" on the inlet and outlet boundary conditions. Velocity BC's are "zeroGradient".
Problem 1: I'm confused on how to switch to cylindrical coordinates, if at all possible.
Problem 2: I've made the model using pimpleDyMFoam and it's been running for 2 days now and hasn't converged. It's close... i think, but I want to test several pressure gradients. A rotating mesh seems computationally extensive.
I'm hoping for a simple solution and sure there is one.
I'm running OF 2.3 on Ubuntu 14.04 (Just reinstalled). i understand some older versions of OpenFoam have more BC's so if it is install an older version of OpnFoam, then so be it.
Thanks in advance
ling40 is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Radiation interface hinca CFX 15 January 26, 2014 17:11
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
