May 13, 2015, 06:14 |
bad convergence of k-omega SST model
Liam
Rep Power: 12 |
Hi foamers,
I am trying to do an internal flow computation using k-omega SST model in OpenFOAM. The solver used is simpleFoam. After reading several posts and theoretical, I am a bit lost yet...I cannot reach a convergent solution of my model. The mesh is created with cfMesh. About 5 layers of prism cells are placed close to the wall of the bifurcated pipe. The first layer height is about 5e-05. I have tried several BCs for k, omega and nut. I attach the main 3 options I have used. Simulation residuals never fall below 1e-03 (for pressure it uses to be 1e-02). So, here are my questions: 1. The yPLus value I have obtained using yPlusRAS utility (some people say that it is ystar, I have not read the code yet) is about 2-3. I want to resolve boundary layer ,so, could this be the problem? Should I go to a yplus value of 1 or below? Is this really the theretical yPlus? Can I apply wall functions in this case (I think wall function approach is better for a not well resolved mesh at the boundary, let's say yPlus between 30 and 300 or so)? 2. CheckMesh present some warnings, but I guess these come from the cells close to the wall, which are expected to be high aspect ratio cells. What about non orthogonal correctors? 3. As I am not finding a convergent solution, I started to think in solvers in fvOptions and discretization schemes in fvSchemes. I attach it too. I would like to go to second order schemes. 4. I know that my initial values could be better computed, but at the beginning the simulation residuals fall fast. The poblem is that at some point, they stay constant in a quite high value, although both flow rate and averaged outlet velocity remain constant. Do you think initial values could have influence in the convergence behaviour after several iterations? I am using OF 2.2.2, but I will update to 2.3 soon. Thanks in advance. I cannot solve this! NOTE that in attached files sometimes one of the inlets is treated as a wall. This is not a mistake, I have decided to close it for some reasons, but the residuals behaviour is almost the same... |
May 13, 2015, 06:22 |
Liam
Rep Power: 12 |
Sorry; I forgot to attach fvSolution and fvSchemes files.
I include also Residual plot, checkMesh output and meshDict (one of them) used. |
May 13, 2015, 06:31 |
Liam
Rep Power: 12 |
Just one more thing, why I cannot compute yplus when I use something different than nutUSpalding WF or similar at the wall?
August 10, 2015, 15:15 |
#4 | ||||
Rep Power: 12 |
Hi Liam,
a few thoughts on some of your questions: Quote:
Low Reynolds Number SST Model | Josh | CFX | 41 | June 4, 2023 19:00 |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
DrivAer car model Convergence | MarkT | FLUENT | 0 | April 21, 2015 10:23 |
wall treatment k-w SST model in Fluent | behest | FLUENT | 0 | December 26, 2014 08:14 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
