alphaEff
Like Tree25Likes
  • 2 Post By zahraa
  • 3 Post By alexeym
  • 20 Post By pmdelgado2
Old   June 22, 2015, 22:44
Default alphaEff
zahra
zahraa is on a distinguished road
Hello foamers,
I would like to find the difinition of alphaEff() wich is used in hEqn.H in following form :
fvm::laplacian(turb.alphaEff(), h)
Does anyone know where "alphaEff()" is defined?
amuzeshi and erinsam like this.
zahraa is offline   Reply With Quote
Old   June 23, 2015, 02:27
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
I guess, turb in your message is compressible turbulent model, so for RAS alphaEff is defined as
virtual tmp<volScalarField> alphaEff() const
    return thermo().alphaEff(alphat());
for LES it is
    return thermo().alphaEff(alphaSgs());
and finally thermo.alphaEff() is http://foam.sourceforge.net/docs/cpp...b7cebc3adf4b1d
tariq, zahraa and amuzeshi like this.
alexeym is offline   Reply With Quote
Old   August 19, 2016, 12:47
Paul
pmdelgado2 is on a distinguished road
It took me a very long time to figure this one out. The reason why it took me (and probably you) so long is because of the complicated structure of openFoam's thermophysical classes.
As alexeym indicates, no matter which type of turbulence model you choose (RAS or LES), the turbulence model will have a call to a thermophysical model. Searching through the various files, i figured out that in
/src/thermophysicalModels/basic/heThermo/heThermo.C
you will find a line that says something along the lines that
alphaEff = CpByCpv* (alpha + alphat)
I haven't found any other thermophysical model that also says this (if anyone discovers another one like this, please post a reply!!)
Note: alpha is defined in the
/src/thermophysicalModels/basic/basicThermo/basicThermo.H
as having the units kg/m/s. This probably looks strange to you knowing that thermal conductivity (kappa) usually has units of kg*m/s^3/k, where k is the degrees in kelvin.
In effect, alpha is known as the thermal diffusivity for the enthalpy of a mixture, where as kappa is the thermal diffusivity for temperature. The relation between the two is that
kappa = alpha * Cp,
where Cp is the specific heat capacity at constant pressure.
You may also notice that the definition of alphaEff above is also scaled by a factor of CpByCpv. CpByCpv = Cp/Cpv, where Cpv is the specific heat capacity at constant pressure/volume.
Depending on which energy model you use, e.g. sensibleEnthalpy, then
cpbycpv = 1
since it is assumed that cp=cpv.
If you use sensibleInternalEnergy, then
cpbycpv = Cp/Cv,
where cv is the specific heat capacity at constant volume.
The different types of energy models can be found in the directory
src/thermophysicalModels/specie/thermo
However, keep in mind that some solvers limit which of these energy models that you can use.
pmdelgado2 is offline   Reply With Quote
Old   September 1, 2016, 06:37
Paritosh Vasava
vasava will become famous soon enough
Did you mean, alphaEff is known as the thermal diffusivity for the enthalpy of a mixture, where as kappaEff is the thermal diffusivity for temperature?
You mean that kappa is the thermal conductivity, right?
vasava is offline   Reply With Quote
Old   December 8, 2016, 16:13
Hasan Celik
PositronCascade is on a distinguished road
Dear Paritosh,
kappa is thermal diffusivity in OpenFOAM, isn't it correct? And I think it is Alpha / Cp as OpenFOAM SIMPLE solvers neglect the rho.
PositronCascade is offline   Reply With Quote
Old   May 17, 2020, 08:43
Ali Shayegh
amuzeshi is on a distinguished road
Originally Posted by alexeym View Post
I guess, turb in your message...
...and finally thermo.alphaEff() is http://foam.sourceforge.net/docs/cpp...b7cebc3adf4b1d
Dear alexy,
The link has been corrupted. Please include a new one, as your description is insightful.
amuzeshi is offline   Reply With Quote
Wall with fixed heatFlux boundary condition Martin Lorenz (Lorenz) OpenFOAM Running, Solving & CFD 33 December 21, 2020 05:59
Fixed heat flux BC in buoyantPimpleFoam bhh OpenFOAM Running, Solving & CFD 39 January 12, 2019 08:51
Heat flux calculating with wallHeatFlux utility and alphaEff tanshihaj OpenFOAM Post-Processing 0 March 12, 2014 05:55
Accessing fields and dictionaries from within a BC implementation alberto OpenFOAM Running, Solving & CFD 12 December 6, 2011 09:30
alphaEff scalarField deji OpenFOAM 1 July 29, 2010 14:12
