Viscous Layers generating defaultFaces
Old   July 20, 2015, 08:50
Default Viscous Layers generating defaultFaces
James F.
NoradFirst2 is an unknown quantity at this point
Hi Foamers,
I have a problem with Salome/OpenFoam.
There is a viscous layer in my current mesh and it is generating a problem once I export it to UNV to use it in OpenFoam later: the viscous layer is generating a face which is identified when I export to OpenFoam and create a defaultFace I cannot get rid off.
(I first had this defaultFace poping, I went on paraFoam to see it and it was a face 3mm above my actual wall corresponding to the last viscous layer...)
Does anyone has an idea on how to handle this problem? It never appeared before... Thanks :')
EDIT: The ideasUnvToFoam command is telling me at the end:
FOAM Warning: [...] Found 31920 undefined faces in mesh; adding to default patch.
The thing is I cannot find those faces in Salome.
EDIT2: checkMesh is telling me there are two regions in my mesh which is not normal. I should probably try to merge these two regions into one. Somehow...
EDIT3: Everything is fine as long as I remove the viscous layers.
NoradFirst2 is offline   Reply With Quote
Old   July 20, 2015, 09:46
James F.
"Solved" my problem by computing the mesh again... It was a bug I guess.
Old   July 23, 2015, 05:09
James F.
Well, I changed some parameters in my mesh to improve my computation but the problem is coming back and I cannot get ride off it by simply computing the mesh again and again... Any idea to fix my problem properly?
Old   February 2, 2016, 05:04
Christof Schmidt
cristopf is on a distinguished road
I have exactly the same problem. I donīt know how to solve that. Could you find a way to handle it in the meantime?
cristopf is offline   Reply With Quote
Old   June 21, 2018, 05:49
Deep
deepbandivadekar is on a distinguished road
@NoradFirst2 or @cristopf were you able to solve this?
deepbandivadekar is offline   Reply With Quote
[ICEM] Prism layers distorted near trailing edge of blade-Unstructured Mesh Rohith Giridhar ANSYS Meshing & Geometry 3 June 29, 2015 17:52
run Doxygen offline anishtain4 OpenFOAM 8 November 27, 2014 09:36
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 11:40
ParaView and Qt 4.3.5 on Mac OS X 10.6 Adrian OpenFOAM 3 August 8, 2010 03:16
TGRID- Problem in generating Viscous Mesh abhinit FLUENT 3 January 8, 2007 08:48
