tank pump out - multiphaseInterFoam
Old   August 11, 2015, 17:06
Default tank pump out - multiphaseInterFoam
Klaus R Menschig
KlausR is on a distinguished road
I want to simulate the emptying of an open tank by pumping it out through a nozzle by applying multiphaseInterFoam. I have two liquid phases with different densities and an air phase on top. I have applied a fixedValue outlet flow at the nozzle exit and a zeroGradient pressure boundary at the outlet. I read somewhere else that setting a fixedValue at outlet would not work, but I do not think I have a choice. I get unexpected results however (see attachments).
1) Although the heavy phase is below the nozzle, flow of the heavy phase through the nozzle is observed during the whole run. Why can I not see the top phase flow through the nozzle?
2) At the end of the run, when the tank level is below the nozzle the pressure at the nozzle exit catapults to the highest values and I do not understand why?
Thanks for any help, hint, etc.
- Klaus
File Type: gz 0.org.tar.gz (907 Bytes, 0 views)
KlausR is offline   Reply With Quote
Need Help! High pressure Gas discharge from tank to tank through a pipe superarthur86 FLUENT 2 June 16, 2017 10:22
Tank refuelling simulation Bisht STAR-CCM+ 4 July 30, 2015 11:02
error messages about blockmeshing and solving cramsdead OpenFOAM Pre-Processing 2 November 11, 2014 10:53
Mixture and Decay of a tracer in a Water Tank Jeffrey1992 CFX 2 July 27, 2012 13:31
Blow Tank Simulation ... Need Help! treyevans CFX 1 February 20, 2010 00:42
