November 14, 2015, 04:15 |
Messed up with the Rising Bubble :(
#1 | ||
L
Rep Power: 10 |
Hi,everyone. I'm a green hand in using OpenFOAM. These days I'm trying to simulate a rising bubble(2D) in a column of water by interFoam. The bubble rises from the bottom of the box and emerges from the water surface. It might be an easy task for you, but I have came up against several problems. Could you help me? 1. According to my results, the bubble floats to the left of the column and stops at the top. But in my imagination, the bubble should blow up and disappear into the air. I think maybe my OUTLET's BC has effects on the water flow. So is there anyting wrong with my OUTLET's BC. 2. I use setFields(sphereToCell) to make a bubble in the water. It works. And then I try to create an area full of air above the water surface. So I edit my setFieldsDit in the same way. As shown below. Quote:
November 17, 2015, 17:28 |
Kaufman
Rep Power: 12 |
box(0 0.025 0)(0.015 0.03 0.0001);
^ box (0 0.025 0)(0.015 0.03 0.0001); with space |
November 18, 2015, 22:58 |
L
Rep Power: 10 |
interfoam bubble |
Rising bubble with interFoam | tayo | OpenFOAM Running, Solving & CFD | 16 | March 12, 2020 12:11 |
A rising bubble in a stagnant liquid with two-fluid-model | fs82 | OpenFOAM Running, Solving & CFD | 30 | August 18, 2016 12:27 |
bubble rising problem | swamysrikanth | ANSYS Meshing & Geometry | 3 | May 31, 2016 11:09 |
2D bubble rising through a column of water | vof64 | Fluent Multiphase | 0 | August 19, 2014 23:42 |
bubble rising in a column | swamysrikanth | Main CFD Forum | 2 | September 27, 2010 08:59 |
