Multiphase Injector Combustion File Setup Problems
Like Tree1Likes
  • 1 Post By sim2599
Old   March 16, 2016, 15:29
Question Multiphase Injector Combustion File Setup Problems
SCHOLZC is on a distinguished road
I am trying to setup a case which models a triplet injector. I have defined each of the species (reacting and products) in separate thermophysicalProperties files, and input the appropriate corresponding parameters for each (I am not sure if this is the best way to do it since I am relatively new to OpenFOAM). I am trying to model a Methane Reaction (CH4(liquid) & O2(liquid) reactants, CO2 & H2O biproducts), but as soon as the compilation (when attempting to run) reaches the O2 properties (which uses a reacting Mixutre instead of a pureMixture for the biproducts), it goes to reference the "reactions" file. I have looked at the BubbleColumnEvaporatingReacting tutorial and files, which have provided some guidance, but it seems that my model (which is running reactingMultiphaseEulerFoam) is requiring a different setup, or something is ill defined. It is only recognizing O2 as a viable species to refer to, and when including other species in the list it gives:
--> FOAM FATAL ERROR:
CO2 not found in table. Valid entries: 1(O2)
From function HashTable ...
If I remove all other species, it says that the "sum of mass fractions is zero for species 1(O2)". I have defined all of the species in phaseProperties & thermo.compressibleGas. Are there files I am missing or not attending to here? How can I resolve this issue?
Thank you! :-)
SCHOLZC is offline   Reply With Quote
Old   March 17, 2016, 15:07
Default Follow-up
I was able to resolve the species not being recognized. I am now have issue with the following error:
Sum of mass fractions is zero for species
Does anyone know where this is resolved?
Thanks!
Old   March 19, 2016, 15:34
Vinícius da Costa Ávila
avila.vc is on a distinguished road
Hi, I have never dealt with this specific solver. But have you tried to modify just the phases names and proprieties from tutorials/multiphase/reactingMultiphaseEulerFoam/laminar/mixerVessel2D ? This case seems to be pretty well settled for 4 phases.
Vinícius dC.A.
avila.vc is offline   Reply With Quote
Old   December 29, 2018, 13:50
sim2599 is on a distinguished road
Hi Scholzc,
How did you resolve the issue of the species not being recognized?
tomi24 likes this.
sim2599 is offline   Reply With Quote
Old   June 17, 2020, 01:19
krishna kant
kk415 is on a distinguished road
Hi All,
I am also facing the same error of "Sum of mass fractions is zero for species 2(N2 H2O)". I am using sprayFoam solver in OpenFoam-v1912.
My thermophysicalProperties file looks like this.
|  \\    /   O peration     | Version:  v1912                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            hePsiThermo;
    mixture         multiComponentMixture;
    transport       const;
    thermo          hConst;
    energy          sensibleEnthalpy;
    equationOfState perfectGas;
    specie          specie;
species         (N2 H2O);
N2
    specie
        molWeight   28;
		Y			0.5;
    thermodynamics
        Cp          1000;
        Hf          0;
    transport
        mu          1.5e-5;
        Pr          0.7;
H2O
    specie
        molWeight   28;
		Y			0.5;
    thermodynamics
        Cp          4187;
        Hf          0;
    transport
        mu          1e-6;
        Pr          0.7;
inertSpecie     N2;
liquids
    H2O
        defaultCoeffs   yes;
solids
Any help will be deeply appreciated. I need to solve this problem soon.
kk415 is offline   Reply With Quote
Old   June 17, 2020, 23:13
krishna kant
It is resolved by adding the species file in the 0 folder.
combustion, injector, reacting flow
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 17:25
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
