complex eigenvalues detected for tensor
Old   April 6, 2016, 07:10
Default complex eigenvalues detected for tensor
thegauravonline's Avatar
GS
thegauravonline is on a distinguished road
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     3.2                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (-5   0    -2.4)
    (0    0    -2.4)
    (0.04 0    -2.4)
    (10    0    -2.4)
    (-5   2.6  -2.4)
    (0    2.6  -2.4)
    (0.04 2.6  -2.4)
    (10    2.6  -2.4)
    (-5   2.8    -2.4)
    (0    2.8    -2.4)
    (0.04 2.8    -2.4)
    (10    2.8    -2.4)
    (-5   0     2.4)
    (0    0     2.4)
    (0.04 0     2.4)
    (10    0     2.4)
    (-5   2.6   2.4)
    (0    2.6   2.4)
    (0.04 2.6   2.4)
    (10    2.6   2.4)
    (-5   2.8     2.4)
    (0    2.8     2.4)
    (0.04 2.8     2.4)
    (10    2.8     2.4)
blocks
    hex (0 1 5 4 12 13 17 16) (40 20 10) simpleGrading (0.1 0.2 1)
    hex (2 3 7 6 14 15 19 18) (80 20 10) simpleGrading (10 0.2 1)
    hex (4 5 9 8 16 17 21 20) (40 20 10) simpleGrading (0.1 2 1)
    hex (5 6 10 9 17 18 22 21) (5 20 10) simpleGrading (1 2 1)
    hex (6 7 11 10 18 19 23 22) (80 20 10) simpleGrading (10 2 1)
edges
patches
    patch consoleFluid
        (1 13 17 5)
        (5 17 18 6)
        (6 18 14 2)
    wall topWall
        (8 20 21 9)
        (9 21 22 10)
        (10 22 23 11)
    wall bottomWall
        (0 1 13 12)
        (2 3 15 14)
    patch outlet
        (3 7 19 15)
        (7 11 23 19)
    wall inlet
        (0 12 16 4)
        (4 16 20 8)
    wall frontAndBackPlanes
	(0 4 5 1)
	(4 8 9 5)
	(5 9 10 6)
	(2 6 7 3)
	(6 10 11 7)
	(12 13 17 16)
	(16 17 21 20)
	(17 18 22 21)
	(14 15 19 18)
	(18 19 23 22)
mergePatchPairs
This code runs fine for my geometry.
but when I change the convertToMeters 0.01 in the same blockMeshDict, i get an error after 6th iteration of first time step saying "complex eigenvalues detected for tensor"
Time = 0.01, iteration: 6
Current fsi under-relaxation factor (Aitken): 0.000591848
Maximal accumulated displacement of interface points: 0.0249799
DICPCG:  Solving for motionUx, Initial residual = 0.0630508, Final residual = 6.27685e-05, No Iterations 456
DICPCG:  Solving for motionUy, Initial residual = 0.320541, Final residual = 0.000320251, No Iterations 104
DICPCG:  Solving for motionUz, Initial residual = 0.199232, Final residual = 0.000198682, No Iterations 327
Courant Number mean: 0.258629 max: 27.4461 velocity magnitude: 0.391973
DILUPBiCG:  Solving for Ux, Initial residual = 0.705221, Final residual = 4.49245e-07, No Iterations 16
DILUPBiCG:  Solving for Uy, Initial residual = 0.900522, Final residual = 8.65619e-07, No Iterations 15
DILUPBiCG:  Solving for Uz, Initial residual = 0.628637, Final residual = 9.8274e-07, No Iterations 19
GAMG:  Solving for p, Initial residual = 0.963762, Final residual = 9.44056e-07, No Iterations 70
GAMG:  Solving for p, Initial residual = 3.71152e-07, Final residual = 3.1966e-07, No Iterations 1
time step continuity errors : sum local = 3.68598e-07, global = -8.70958e-10, cumulative = -8.63331e-10
GAMG:  Solving for p, Initial residual = 0.403809, Final residual = 9.54625e-07, No Iterations 60
GAMG:  Solving for p, Initial residual = 1.6799e-06, Final residual = 9.24074e-07, No Iterations 4
time step continuity errors : sum local = 5.16904e-07, global = 1.21874e-09, cumulative = 3.55412e-10
Setting traction on solid patch
Total traction force = (0.000978828 3.34429e-05 2.30297e-06)
--> FOAM Warning :
    From function eigenValues(const tensor&)
    in file primitives/Tensor/tensor/tensor.C at line 170
    complex eigenvalues detected for tensor: (0.368474 -0.159926 0.561094 -0.0315612 -0.0259822 0 -1.56993 -1.03141 1)
--> FOAM Warning :
--> FOAM Warning :
    complex eigenvalues detected for tensor: (0.337311 -0.186135 0.565656 -0.072027 -0.142593 0 -1.60081 -1.05708 1)
--> FOAM Warning :
What is going wrong with this?
thegauravonline is offline   Reply With Quote
Old   October 10, 2016, 11:20
Ting
tbao is on a distinguished road
Originally Posted by thegauravonline View Post
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
convertToMeters 1;
vertices
    (-5   0    -2.4)
    (0    0    -2.4)
    (0.04 0    -2.4)
    (10    0    -2.4)
    (-5   2.6  -2.4)
    (0    2.6  -2.4)
    (0.04 2.6  -2.4)
    (10    2.6  -2.4)
    (-5   2.8    -2.4)
    (0    2.8    -2.4)
    (0.04 2.8    -2.4)
    (10    2.8    -2.4)
    (-5   0     2.4)
    (0    0     2.4)
    (0.04 0     2.4)
    (10    0     2.4)
    (-5   2.6   2.4)
    (0    2.6   2.4)
    (0.04 2.6   2.4)
    (10    2.6   2.4)
    (-5   2.8     2.4)
    (0    2.8     2.4)
    (0.04 2.8     2.4)
    (10    2.8     2.4)
blocks
edges
patches
    patch consoleFluid
        (1 13 17 5)
        (5 17 18 6)
        (6 18 14 2)
    wall topWall
        (8 20 21 9)
        (9 21 22 10)
        (10 22 23 11)
    wall bottomWall
        (0 1 13 12)
        (2 3 15 14)
    patch outlet
        (3 7 19 15)
        (7 11 23 19)
    wall inlet
        (0 12 16 4)
        (4 16 20 8)
	(0 4 5 1)
	(4 8 9 5)
	(5 9 10 6)
	(2 6 7 3)
	(6 10 11 7)
	(12 13 17 16)
	(16 17 21 20)
	(17 18 22 21)
	(14 15 19 18)
	(18 19 23 22)
mergePatchPairs
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Did you solve this problem? I met the same problem but have not solved yet. Any hit is appreciated.
tbao is offline   Reply With Quote
Old   January 10, 2017, 15:23
Karthick
KarthickRajkumar is on a distinguished road
Originally Posted by tbao View Post
I am doing implementation of compressible flow solver in FSI library in foam -extend 3.2, where I face this similar problem!
Did you fix it? If so, could you please share how did you do it!
Thanks,
Karthick
KarthickRajkumar is offline   Reply With Quote
Old   January 14, 2017, 05:18
GS
Yes I did solve it. But I just cant remember what the problem was.
I think it was something due to inappropriate material properties.
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
Problem with complex eigenValues Harak OpenFOAM Running, Solving & CFD 11 January 26, 2016 01:48
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
