wallShearStress Multiphase Turbulent Mesh-dependend
Old   April 15, 2016, 03:35
Default wallShearStress Multiphase Turbulent Mesh-dependend
Stefan
StefanW is on a distinguished road
Dear Foamers
I try to simulate a turbulent twophase pipe-flow (water/air) to get the upcomming wall Wall Shear Stresses and i got really in trouble to get the things sorted.
I use OF 2.01 and the solver compressibleInterFoam with a k-w-SSt model.
As discussed in many threads the OF utility wallShearStress dosn't work for multiphase according some problems with transportProperties.
So I look for a way to compute them otherwise.
I made a solution for multiphase like the following which works well and recognizes the two phases
tau=twoPhaseProperties.mu()*symm(fvc::grad(U))
I did some testings with different mesh-sizes with the mentioned function
and the values of Tau got nearly double if I half the size of the elements.
But the behavior of the "main" flow in the middle of the pipe is nearly the same (vel,p) in both cases, so I would guess the mesh size is fine enough in both cases.
I also found this Thread
http://www.cfd-online.com/Forums/ope...interfoam.html
where is mentioned that we have to use different kinds of calculations if the flow is laminar or turbulent.....
I got a turbulent flow therefore it is suggested to use and not the one above:
wallShear = (-mesh.Sf().boundaryField()[patchID]/(mag(mesh.Sf().boundaryField()[patchID])) ) & (turbulence->R()().boundaryField()[patchID])
Could somebody please explane the single parts of the equation?
Is there mu already attached? So I have to multiply it with mu?
Additionally I got a generall question according the influence of the mesh-size near the wall on the calculated values of the shear stresses.
So far I wasn't able to check the y+ values (yPlusRas) cause the utility doesn't work in multiphase as well. (I use wall functions but i cant figure out how to extract y+; help here would also be appreciated; I found the variable "ypl" in the wallfunction of omega
https://github.com/OpenFOAM/OpenFOAM...hScalarField.C
but i'm not sure if that would help and how to extract it)
So should my function work correctly just in the viscous sublayer when y+ < 5 so we see laminar behavior between the wall and the first cell? And if I enter the <5 the further mesh size doesn't matter and the shear stresses will be the same values???
Would the function for turbulent cases solve this problem so I can use meshes with
y+>30 (logarithmic region) and get still similar results?
(Kind of the same principle the wall functions are working with the blending factor of Mentner k-w-sst)
So basically that leads to the question what setup is needed so OF calculates the normal gradient du/dy correctly. And how OF interpolates the velocity between the wall(0) and the first cell.
I hope anybody can follow my explanations and can give me some hints.
Thanks a lot in advance
Stefan
StefanW is offline   Reply With Quote
Old   May 4, 2016, 06:31
Stefan
nobody got any ideas according this??
mesh and grid, wall boundary conditions, wallfunctions, wallshearstress, yplusras
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
How to make a smooth interface for multiphase flow with dynamic mesh? aegean333 OpenFOAM Programming & Development 0 May 10, 2013 05:34
[ANSYS Meshing] 3d wind turbine mesh for multiphase simulation mingersai ANSYS Meshing & Geometry 0 January 17, 2012 18:20
