Individual Heat Generation Terms using fvOptions |
Anon
Rep Power: 0 ![]() |
I am running an simulation where I require heat generation in a fluid flow. Currently I am using buoyantSimpleFoam however, I believe this problem can be expanded to all solvers that have fvOptions implemented. I am implementing my heat generation terms by using the points terminology and the scalarSemiImplicitSource. My goal is to have a list of points and then there respective heat generation terms as well. (Below I have given an example with two points). The issue is that the points only use the first heat generation term, i.e. the (10 0). I have tried putting them into a list as well, i.e. h ((10 0) (1000 0)). However that just errors out OpenFOAM, with the error being that it expects a scalar instead of (. Is there any way around this with out having list a different source for each heat generation source? Code:
source1 { type scalarSemiImplicitSource; active yes; scalarSemiImplicitSourceCoeffs { selectionMode points; points ( (0.5 0.5 0) (2.5 0.5 0) ); volumeMode absolute; injectionRateSuSp { h (10 0) (1000 0); } } } |
Nima Samkhaniani
Rep Power: 24 ![]() |
As you have two heat generations, you need define two source not one
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
fvoptions, heat generation |
How to Define heat generation rate that changes with the system coordinate. | a19910112a | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 03:22 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Internal Heat generation problem | ldcairan | ANSYS | 0 | November 19, 2010 13:21 |
Natural Convection with heat generation | krishnachandranr | Main CFD Forum | 0 | July 28, 2009 04:22 |
Calculation of heat generation in Fluent for 2D | krishnachandranr | FLUENT | 0 | April 7, 2009 23:31 |
