Mapping values to inlet (from samples) with different # of points at each time step |
#1 | |
Rep Power: 11 ![]() |
Hi everyone,
I have a case with moving airfoils to influence the flow. Since I am not actually interested in the moving airfoils but in their wake, I simulated the moving airfoils and probed the wake with a surface. My plan is to use the results as an input for future simulations at the inlet so I do not need to simulate the airfoils and to avoid a moving mesh. I was able to move the post processing files (surface via probe in OF-Format) files to constant/boundaryData/inlet for each time step and add the correct header (comparable to the example for timeVaryingMappedFixedValue, just for each time step I resolved). Two questions arose to me: 1. Will OpenFoam interpolate the timesteps inbetween? 2. How do I handle the fact that the amount of points differ between the time steps? So far I used probed via a cutting plane surface. This results in the aforementioned different amout of points and thus in this error: Quote:
Any help to solve this is appreciated. Since the flow is complex i cannot discribe it via GroovyBC though. Sincerely, Henning Last edited by HenningW; August 22, 2016 at 03:55. |
boundary conditions, points, sample surface, timevaryingmappedfixedval |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
time step directories naming issue | Andrea_85 | OpenFOAM | 3 | April 3, 2014 08:38 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
