noise in U at the free surface in InterFoam
Old   October 15, 2016, 22:29
Default noise in U at the free surface in InterFoam
Lee Jung Hoo
Jung hoo is on a distinguished road
Hello foamers, I set a simple water tank with InterFoam.
First, I didn't generate any flow to evaluate stability.
The upper boundary is set as atmosphere.
Obviously, It seems that there should not be flow rate, but there is some flow rate consistently at the free surface(about 0 ~ 0.3 of magnitude).
I'm planning to set the temperature over the air and water later.
I think that the noise at the free surface in U will affect the distribution of temperature because the convection term includes the flux(phi).
How can I remove the noise?
Any comments will be very helpful.
Thanks!
Jung hoo is offline   Reply With Quote
Old   October 16, 2016, 21:27
Pablo Higuera
Phicau is on a distinguished road
Hi Jung Hoo,
unfortunately this is a well known issue with no solution yet.
There are extensive discussions here in the forum on how to make it milder. You should look for threads talking about spurious velocities or spurious currents.
Best,
Pablo
Phicau is offline   Reply With Quote
Old   October 17, 2016, 01:54
Lee Jung Hoo
Thank you for your kind reply. I'll check them!
Thermocapillary free surface flow zakifoam OpenFOAM Running, Solving & CFD 10 December 12, 2016 11:44
interFoam stability issue, free surface ship hull jojosaxo OpenFOAM Running, Solving & CFD 5 July 7, 2016 17:29
ras interFoam for free surface modeling ms.mahsa OpenFOAM Pre-Processing 0 April 18, 2016 12:11
free surface modelling using VOF sci Main CFD Forum 10 August 29, 2012 07:43
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
