How to use result of one simulation as a Boundary Condition in another simulation? |
May 20, 2020, 23:58 |
#21 | |
Rep Power: 10 |
I am assuming that you are trying to sample the patch values. The sampling process is different in the newer version. The following worked for me:
The sampled patch values will be generated in the correct format in the postProcessing/singleGraph/ directory. Cheers, USV |
May 21, 2020, 06:24 |
#22 |
Arijit Saha
Rep Power: 7 |
========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | ------------------------------------------------------------------------------- Description Writes graph data for specified fields along a line, specified by start and end points. \*---------------------------------------------------------------------------*/ start (0 1e-06 0); end (1 1e-06 0); fields (U p); // Sampling and I/O settings #includeEtc "caseDicts/postProcessing/graphs/sampleDict.cfg" // Override settings here, e.g. /* setConfig { type lineCell; axis x; // y, z, xyz } */ // Must be last entry #includeEtc "caseDicts/postProcessing/graphs/graph.cfg" // ************************************************** *********************** // It is giving the value along a line and the singleGraph folder looks like this which is quite different from yours. |
May 21, 2020, 06:28 |
#23 | |
Rep Power: 10 |
USV |
May 21, 2020, 06:37 |
#24 |
Arijit Saha
Rep Power: 7 |
--> FOAM FATAL IO ERROR:
keyword interpolationScheme is undefined in dictionary "controlDict.functions.singleGraph.singleGraph " file: controlDict.functions.singleGraph.singleGraph from line 20 to line 34. From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 573. When I run the command it is showing up this error. What can I do any idea? |
May 21, 2020, 06:43 |
#25 | |
Rep Power: 10 |
singleGraph { ... interpolationScheme blah; // blah = some dummy value ... } USV |
May 21, 2020, 07:01 |
#26 |
Arijit Saha
Rep Power: 7 |
| ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object singleGraph; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // singleGraph { type surfaces; libs ("libsampling.so"); writeControl writeTime; interpolationScheme blah; fields ( U ); surfaceFormat boundaryData; surfaces ( right_patch { type patch; patches ("right"); // patch names interpolate true; } ); } // ************************************************** *********************** // I used cell, cellPoint, blah but now it is not showing up in the post-processor directory. Even when I used blah it didnt pop up any error. |
May 21, 2020, 07:05 |
#27 | |
Rep Power: 10 |
By the way, do you have a patch named 'right'? If not, please try using one of your patches. USV |
May 21, 2020, 07:27 |
#28 |
Arijit Saha
Rep Power: 7 |
Sir, actually I was trying to extract one surface from the pitzdaily case and feed that output velocity into the inlet. I did that by using surface dict and that gave the velocity at all points i.e 62 velocities but I want the velocity corresponding to the faces i.e 30 velocity component so that I can feed that in input. But at this point I m unable to extract the velocity corres to each face at that specific surface. I had put the patch name as"surfaces" still it didnt work and even I cant send you the file because it is exceeding the limit. Any kind of help will be really great.
May 21, 2020, 10:27 |
#29 | |
Rep Power: 10 |
USV |
May 21, 2020, 10:49 |
#30 |
Arijit Saha
Rep Power: 7 |
Didnt work also after putting outlet as the name of the patch.
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Change a boundary condition based on simulation result and recompute the simulation | Robin.Kamenicky | CFX | 1 | March 7, 2017 18:35 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
turbineSiting tutorial: slip condition at top boundary gives unexpected result | letzel | OpenFOAM | 0 | June 6, 2014 05:25 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
