Need methane reaction mechanism
Old   January 8, 2016, 12:55
Default Need methane reaction mechanism
Tomladian Bucinara
Tom123 is on a distinguished road
Dear everyone,
If anyone have a reduced or skeletal mechanism of methane, please share your .inp and .dat files (chemkin version of openfoam version). Thank you very much.
I am currently running a case about methane combustion using reduced version of GRI-MECH 1.2. 19 species (+ N2, AR) 84 reactions. If the inlet temperature of air was set 300K (experimental condition), the flame will gradually goes to extinction. If the temperature was set 400K or above, things goes right. I have tried using hot (like 1800K) initial temperature condition in the reaction domain, setting many ignition points, increase the resident time of the igition, etc.
Considering changing other reaction mechanisms of methane may solve the problem, I have searched a couple of days but find all of them have problems, for example.
It seems A 19-species reduced mechanism, and a 30-species skeletal mechanism ( http://www.engr.uconn.edu/~tlu/mechs/mechs.htm ) do not give the values of E, A, n.
The 4 step reaction meachnism mentioned here ( http://www.cfd-online.com/Forums/ope...mechanism.html ) do not give a answer.
Thanks again.
Tom
Tom123 is offline   Reply With Quote
Old   May 8, 2018, 03:57
ms6918 is on a distinguished road
I am looking for the similar files but could not get them. Can you kindly share the same.
Thank You
ms6918 is offline   Reply With Quote
Question about reaction mechanism in ReactingFoam Dan1788 OpenFOAM Running, Solving & CFD 6 December 13, 2016 05:09
reduced reaction mechanism for methane combustion using FLUENT vnm ANSYS 1 August 9, 2016 09:25
Jet-A/air reaction mechanism in FLUENT Jenny_W FLUENT 1 November 29, 2013 01:12
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
