Cyclic boundary condition on SALOME mesh
Like Tree10Likes
  • 3 Post By kandelabr
  • 4 Post By kandelabr
  • 1 Post By kandelabr
  • 1 Post By HenrikJohansson
Old   February 20, 2017, 06:59
Default Cyclic boundary condition on SALOME mesh
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
Hello everybody,
I want to set up a cyclic boundary condition on a mesh made in SALOME. I export mesh to i-deas and run ideasUnvToFoam. I get this:
--> FOAM FATAL ERROR:
face 0 area does not match neighbour by 30.6027% -- possible face ordering problem.
I know what that means but I have no idea how to create a mesh that would suit cyclic BC. I haven't found anything on the internet or in this forum so far... I like SALOME but could use something else as well if this can't be done there.
This is my boundary file:
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
|* OpenFOAM for Windows 16.10 (v1)                                           *|
|* Built by CFD Support, www.cfdsupport.com (based on Symscape).             *|
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
8
    CyclicInlet2
        type            cyclic;
        nFaces          592;
        startFace       357723;
        transform	rotational;
        rotationAxis	(0 0 1);
        rotationCentre	(0 0 0);
        neighbourPatch 	CyclicInlet1;
    CyclicOutlet2
        type            cyclic;
        nFaces          2051;
        startFace       358315;
        neighbourPatch 	CyclicOutlet1;
    Inlet
        type            patch;
        nFaces          154;
        startFace       360366;
    ImpellerWalls
        type            wall;
        nFaces          5170;
        startFace       360520;
    VoluteWalls
        type            wall;
        nFaces          9142;
        startFace       365690;
    Outlet
        type            patch;
        nFaces          1946;
        startFace       374832;
    CyclicInlet1
        type            cyclic;
        nFaces          592;
        startFace       376778;
        neighbourPatch	CyclicInlet2;
    CyclicOutlet1
        type            patch;
        nFaces          2051;
        startFace       377370;
        neighbourPatch	CyclicOutlet2;
Thank you!
kandelabr is offline   Reply With Quote
Old   February 20, 2017, 09:34
kandelabr's Avatar
Nejc
It's funny how I banged my head on this for two weeks and now that I gave up and asked I immediately found the solution while looking for something totally different.
For future reference for lost souls like me, here's how it's done:
It's the "Projection" algorithm in SALOME. One face is meshed separately with a submesh, the other is meshed separately again but with Projection 1D-2D algorithm.
http://docs.salome-platform.org/late...lgos_page.html
Enjoy!
zhutaihang, artymk4 and saidc. like this.
Old   May 30, 2018, 10:21
Henrik Johansson
HenrikJohansson is on a distinguished road
Hi Nejc,
How did you solve it with projection 2D. I tried it but can't get it to work.
How do I create a surface mesh before meshing the whole volume or is this the wrong approach?
Could you make a small step by step list on how to do this?
Regards Henrik
/ Henrik Johansson
HenrikJohansson is offline   Reply With Quote
Old   June 1, 2018, 02:12
kandelabr's Avatar
Nejc
Hi, sorry for a late reply, I had to do it again to check if it still works
Here's roughly what to do:
  1. Create a separate patch group on your solid for each side of cyclic patch
  2. Create a mesh on the main solid but don't set any hypotheses on any dimension, just click "apply and close"
  3. Create a sub-mesh on the first cyclic patch, set your hypotheses and calculate it.
  4. Create another sub-mesh on the other cyclic patch and use 'Projection 1D-2D' hypothesis, source mesh: the main mesh from step 2, source face: first cyclic patch group
  5. Calculate the second mesh. Check patches, they should be the same.
See the attachment for a simple example.
Good luck!
Old   December 3, 2018, 03:36
Duc Anh
anhkenyt is on a distinguished road
I was created cyclicBoundary in Salome, but when I convert to OpenFoam and set boundary cyclic (I am using repeatAMi) for them , it this error:
''face 0 area does not match neighbour by 59.88569801% -- possible face ordering problem.
patch:cyclic_Out1 my area:2.01556304e-06 neighbour area:1.086666987e-06 matching tolerance:0.01
Mesh face:591751 fc0.129768 0.05073526667 -0.07932823333)
Neighbour fc0.09832853333 0.00576254 0.01105083333)
If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file.
Rerun with cyclic debug flag set for more information.''
Can anyone help me with this problem?
anhkenyt is offline   Reply With Quote
Old   December 3, 2018, 03:42
Henrik Johansson
Could you share your boundary file?
Maybe you have specified your patches faulty.
Do you use createPatch?
COuld you share your mesh or images of the cyclic boundaries?
/ Henrik
/ Henrik Johansson
Old   December 3, 2018, 06:22
Default Thanks for your repply,
Duc Anh
This is my boundary
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
object boundary;
12
inlet
type patch;
nFaces 891;
startFace 1407711;
cyclicIn1
type patch;
nFaces 1714;
startFace 1408602;
cyclicIn2
type patch;
nFaces 1714;
startFace 1410316;
stationaryWalls
type patch;
nFaces 3076;
startFace 1412030;
couple1
type patch;
nFaces 863;
startFace 1415106;
statorBlade
type patch;
nFaces 4134;
startFace 1415969;
couple2
type patch;
nFaces 2585;
startFace 1420103;
movingWalls
I used CreatePatch
| \\ / O peration | Version: plus |
| \\ / A nd | Web: www.OpenFOAM.com |
FoamFile
version 2.0;
format ascii;
class dictionary;
object createPatchDict;
pointSync false;
patches
// Name of new patch
name cyclic_In1;
// Type of new patch
patchInfo
type cyclic;
neighbourPatch cyclic_In2;
matchTolerance 1E-2;
// How to construct: either from 'patches' or 'set'
constructFrom patches;
// If constructFrom = patches : names of patches. Wildcards allowed.
patches (cyclicIn1);
name cyclic_In2;
patchInfo
type cyclic;
neighbourPatch cyclic_In1;
patches (cyclicIn2);
name cyclic_Out1;
patchInfo
type cyclic;
neighbourPatch cyclic_Out2;
patches (cyclicOut1);
name cyclic_Out2;
patchInfo
type cyclic;
neighbourPatch cyclic_Out1;
patches (cyclicOut2);
and this this images of the cyclicBoudary ( cyclicIn1 and cyclicIn2)
https://drive.google.com/file/d/1D2Q...ew?usp=sharing
https://drive.google.com/file/d/1fjM...ew?usp=sharing
Old   December 3, 2018, 06:51
Henrik Johansson
Thanks,
It is not complaning about the patches you show on the images, cyclicIn1/cyclicIn2, but
There is something wrong with your cyclic_Out1/cyclic_Out2 which are not shown in either images or your boundary file.
/ Henrik Johansson
Old   December 3, 2018, 07:28
kandelabr's Avatar
Nejc
Try specifying more details about your cyclic. In case of rotational symmetry, it would be something like this:
cyclicRight
    type cyclicAMI;
    neighbourPatch cyclicLeft;
    rotationAxis (1 0 0);
   // OpenFOAM usually guesses this correctly
   // rotationAngle 60;
anhkenyt likes this.
Old   December 3, 2018, 07:37
Henrik Johansson
Like Nejc said,
Using cyclicAMI or cyclicGGI could solve the problem. Since they dont care about the face ordering like the cyclic does.
I have never tried using cyclic with 1:1 from Salome just cyclicGGI in foam-extend. Which worked with salomeToOpenFOAM as importer to foam-extend.
Depending on how you export your model from Salome to openfoam the face ordering might not be conserved or even correct for the cyclic condition in OpenFOAM.
/ Henrik Johansson
Old   December 3, 2018, 07:46
Duc Anh
hi Johansson,
Sorry about my mistakes
There ary my boundary and creatPatch
https://drive.google.com/drive/folde...zO?usp=sharing
Old   December 3, 2018, 07:51
Henrik Johansson
Try using cyclicAMI instead of the classic 1:1 cyclic. Since your mesh is 1:1 it shall not make any difference to the result but might increase the solution time slightly.
https://www.cfdsupport.com/OpenFOAM-...t/node116.html
I think the face ordering from Salome of the 1:1 cyclic boundaries are not correct to how OpenFOAM wants it.
/ Henrik Johansson
Old   February 28, 2019, 02:35
Default Problem when using cyclicAMI
  #13
Duc Anh
Hi Johansson,
It's me again, but this time, I used TurborGird for created mesh and imported it to Of6. I tried using CyclicAMI instead of Cyclic but when l run PImpleFoam I am facing an error:
AMI: Creating addressing and weights between 6625 source faces and 6625 target faces
--> FOAM Warning :
    From function void Foam::AMIMethod<SourcePatch, TargetPatch>::checkPatches() const [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>]
    in file lnInclude/AMIMethod.C at line 57
    Source and target patch bounding boxes are not similar
    source box span     : (0.041425 0.0215107 0.096)
    target box span     : (0.0419304 0.0195127 0.096)
    source box          : (0.0874741 0.04003 -0.016) (0.128899 0.0615407 0.08)
    target box          : (0.0897394 0.035125 -0.016) (0.13167 0.0546376 0.08)
    inflated target box : (0.0844115 0.029797 -0.0213279) (0.136998 0.0599656 0.085328)
Unable to set source and target faces
My case is pretty similar to the tutorial Impeller in OF 6.0 and I also follow the setup in that tutorial for boundary conditions.
Please have a look at my geometry in the attached images. My boundaries is like below::
12
    outlet
        type            patch;
        nFaces          6360;
        startFace       4074577;
    movingWalls
        type            wall;
        inGroups        1(wall);
        nFaces          40680;
        startFace       4080937;
    rotorBlade
        type            wall;
        inGroups        1(wall);
        nFaces          33231;
        startFace       4121617;
    statorBlade
        type            wall;
        inGroups        1(wall);
        nFaces          6976;
        startFace       4154848;
    inlet
        type            patch;
        nFaces          1280;
        startFace       4161824;
    stationnaryWalls
        type            wall;
        inGroups        1(wall);
        nFaces          18920;
        startFace       4163104;
    cyclicRepeatAMIInterface1
        type            cyclicRepeatAMI;
        inGroups        1(RepeatAMI1);
        nFaces          1792;
        startFace       4182024;
        inGroups        1 ( RepeatAMI1 );
        name            cyclicRepeatAMIInterface1;
        neighbourPatch  cyclicRepeatAMIInterface2;
        transformPatch  cyclic_Out1;
        inGroups        1(RepeatAMI2);
        nFaces          5565;
        startFace       4183816;
        inGroups        1 ( RepeatAMI2 );
        name            cyclicRepeatAMIInterface2;
        neighbourPatch  cyclicRepeatAMIInterface1;
    cyclic_In1
        type            cyclicAMI;
        inGroups        1(cyclicAMI);
        nFaces          3616;
        startFace       4189381;
        matchTolerance  0.0001;
    cyclic_In2
        type            cyclicAMI;
        nFaces          3616;
        startFace       4192997;
    cyclic_Out1
        type            cyclicAMI;
        nFaces          6625;
        startFace       4196613;
    cyclic_Out2
        type            cyclicAMI;
        nFaces          6625;
        startFace       4203238;
Could you have me on this problem?
Old   February 28, 2019, 07:08
Henrik Johansson
I have no personal experince with cyclicAMI but it looks like there is a problem with your cyclicOut. If you won't figure it out you could try cyclicGGI in foam-extend. That I have used and can help you with.
/ Henrik Johansson
Old   March 2, 2019, 02:40
ducanh
Annken is on a distinguished road
Hi Johansson,
Thanks a lot for guiding me. In boundary file l have edited the cyclicAmi to be made cyclicGGi and which is given below
12
    outlet
        type            patch;
        nFaces          6360;
        startFace       4074577;
    movingWalls
        type            wall;
        inGroups        1(wall);
        nFaces          40680;
        startFace       4080937;
    cyclicOut1
        type cyclicGgi;
        nFaces          6625;
        startFace       4121617;
        shadowPatch cyclicOut2;
        bridgeOverlap off;
        rotationAngle 18;
        separationOffset (0 0 0);
    cyclicOut2
        type cyclicGgi;
        nFaces          6625;
        startFace       4128242;
        shadowPatch cyclicOut1;
        bridgeOverlap off;
        rotationAngle 18;
    rotorBlade
    {   type            wall;
        inGroups        1(wall);
        nFaces          33231;
        startFace       4134867;
    statorBlade
        type            wall;
        inGroups        1(wall);
        nFaces          6976;
        startFace       4168098;
    inlet
        type            patch;
        nFaces          1280;
        startFace       4175074;
    stationaryWalls
        type            wall;
        inGroups        1(wall);
        nFaces          18920;
        startFace       4176354;
    cyclicIn1
        type cyclicGgi;
        shadowPatch cyclicIn2;
        bridgeOverlap off;
        rotationAngle 18;
        nFaces          3616;
        startFace       4195274;
    cyclicIn2
    {   type cyclicGgi;
        nFaces          3616;
        startFace       4198890;
        shadowPatch cyclicIn1;
        bridgeOverlap off;
        rotationAngle 18;
        inGroups
2
cyclicRepeatAMI
RepeatAMI1
        nFaces          1792;
        startFace       4202506;
        transform       unknown;
        method          faceAreaWeightAMI;
        transformPatch  cyclicOut1;
        inGroups
2
cyclicRepeatAMI
RepeatAMI2
        nFaces          5565;
        startFace       4204298;
        transform       unknown;
But I am facing the problem when I run the solver pimpleFoam
     \\/     M anipulation  |
Build  : 6-f934eabb0d52
Exec   : pimpleFoam
Date   : Mar 02 2019
Time   : 10:45:59
Host   : "anh"
PID    : 16781
I/O    : uncollated
Case   : /home/anh/OpenFOAM/OpenFOAM-6/run/ducanh/turbineImpellerNotSnap
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: solidBody
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone inletChannel
PIMPLE: No convergence criteria found
PIMPLE: No corrector convergence criteria found
        Calclations will do 2 corrections
Reading field p
cyclicRepeatAMI : Creating addressing and weights between 1792 source faces and 5565 target faces
Attempt to cast type genericPatch to type coupled
    From function To& Foam::refCast(From&) [with To = const Foam::coupledPolyPatch; From = const Foam::polyPatch]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/typeInfo.H at line 114.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::cyclicRepeatAMIPolyPatch::transformPatch() const at ??:?
#3  Foam::cyclicRepeatAMIPolyPatch::resetAMI() const at ??:?
#4  Foam::cyclicAMIPolyPatch::AMIs() const at ??:?
#5  Foam::tmp<Foam::Field<double> > Foam::cyclicAMIPolyPatch::interpolate<double>(Foam::Field<double> const&, Foam::UList<double> const&) const at ??:?
#6  Foam::cyclicAMIFvPatchField<double>::patchNeighbourField() const at ??:?
#7  Foam::coupledFvPatchField<double>::evaluate(Foam::UPstream::commsTypes) at ??:?
#8  Foam::cyclicAMIFvPatchField<double>::cyclicAMIFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#9  Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::cyclicRepeatAMIFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#10  Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#11  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#12  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#13  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#14  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#15  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#16  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#17  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
Aborted (core dumped)
Can you guide me detail for how to creates cyclicGGi or could you have me on this problem?
Thanks,
Annken is offline   Reply With Quote
Old   March 2, 2019, 04:51
Henrik Johansson
I don't think GGi is implemented in OpenFOAM. You would have to install the extended version to use it. But I think that would be unnecessary. I would try to fix the AMI. Double check your boundary. Maybe there is a typo or you have not pointed to the correct shadow patches.
/ Henrik Johansson
Old   March 22, 2019, 07:09
ducanh
l tried my boundary but l do not see any problem, this is my case, could you help me?
https://github.com/anhkenyt/turbineU...bineTurborCase
Old   March 8, 2024, 04:14
hal_9000 is on a distinguished road
Good luck!
how can it be applied to a hexahedral mesh? the cyclic boundary patches are all faces and my sub-meshes are 1D edges
hal_9000 is offline   Reply With Quote
cyclic bc, openfoam, salome
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
The difference of cyclic boundry condition and mapped boundary condition caitao OpenFOAM Running, Solving & CFD 1 December 4, 2019 07:29
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 04:13
