wrong zero boundary dir in parallel after snappyHexMesh |
March 8, 2017, 03:41 |
Hagen
Rep Power: 9 |
Hi everyone,
I propably miss something basic, nevertheless I have no clue. I am doing parallel computing with OpenFOAM-v1612+ on 3 processors. Procedure is: Code:
blockMesh mpirun -np 3 redistributePar -decompose -parallel Code:
mpirun -np 3 snappyHexMesh -overwrite -parallel Code:
mpirun -np 3 simpleFoam -parallel Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1612+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1612+ Exec : simpleFoam -parallel Date : Mar 08 2017 Time : 09:30:46 Host : "simmachine" PID : 20842 Case : /home/hagen/OpenFOAM/hagen-v1612+/run/stenose/RAS/kOmegaSST/long/steady nProcs : 3 Slaves : 2 ( "simmachine.20843" "simmachine.20844" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading field p [0] [0] [0] --> FOAM FATAL IO ERROR: [0] size 0 is not equal to the given value of 784 [0] [0] file: /home/hagen/OpenFOAM/hagen-v1612+/run/stenose/RAS/kOmegaSST/long/steady/processor0/0/p.boundaryField.inlet from line 26 to line 28. [1] [2] [2] [2] --> FOAM FATAL IO ERROR: [2] Cannot find patchField entry for procBoundary2to0 [2] [2] file: /home/hagen/OpenFOAM/hagen-v1612+/run/stenose/RAS/kOmegaSST/long/steady/processor2/0/p.boundaryField from line 26 to line 42. [2] [2] From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] [2] in file /home/hagen/OpenFOAM/OpenFOAM-v1612+/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 191. [2] FOAM parallel run exiting [2] [0] [1] [1] --> FOAM FATAL IO ERROR: [1] size 0 is not equal to the given value of 1704 [1] [1] file: /home/hagen/OpenFOAM/hagen-v1612+/run/stenose/RAS/kOmegaSST/long/steady/processor1/0/p.boundaryField.outlet from line [0] 32 to line 33. [1] [1] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = double; Foam::label = int] [1] in file From function /home/hagen/OpenFOAM/OpenFOAM-v1612+/src/OpenFOAM/lnInclude/Field.C at line 304. [1] FOAM parallel run exiting Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = double; Foam::label = int][1] [0] in file /home/hagen/OpenFOAM/OpenFOAM-v1612+/src/OpenFOAM/lnInclude/Field.C at line 304. -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [0] FOAM parallel run exiting [0] [simmachine:20840] 2 more processes have sent help message help-mpi-api.txt / mpi-abort [simmachine:20840] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Code:
mpirun -np 3 redistributePar -reconstruct -constant -parallel mpirun -np 3 redistributePar -decompose -parallel If I only decompose again after snappyHexMesh without reconstructing before, I end up getting only the blockMesh. I appreciate any recommondations. Thank you. |
March 8, 2017, 09:30 |
Solved
Hagen
Rep Power: 9 |
Ok, I found a solution for that.
Seems that OpenFoam somehow gets confused with the information from the zero folder. By using an empty dummy zero folder in your case directory, no zero folder will be created in the processor folders. So after snappyHexMesh you can use Code:
restore0Dir -processor And afterwards simpleFoam runs just fine. By the way, with an older version (v1606+) I still struggeled with some ProcAddressing issues. This can be solved by using Code:
mpirun -np 3 renumberMesh -overwrite -constant -parallel Best, Hagen |
March 13, 2017, 04:47 |
Solved 2
Hagen
Rep Power: 9 |
I realized, I have forgotten to mention one important thing:
You need to have a Code:
"proc.*" { type processor; } Best, Hagen |
boundary, parallel, snappyhexmesh |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
