April 26, 2017, 10:01 |
Setting time varying flow field in OpenFOAM
Weiye Ding
Rep Power: 10 |
Hello everyone,
I'm a newbie in OpenFoam. There is a problem which I have already searched from the internet for many days and still have not been solved. The problem is : whether OpenFOAM is able to achieve the velocity like the following U=sin(2*pi*y)*sin(pi*x)*cos(pi*t/T) pi = 3.14 T is the period t is the current time Thanks Tings |
April 26, 2017, 11:22 |
Guess, you need this velocity at the inlet boundary and x, y denote centres of faces. Use codedFixedValue BC. You can find an example in $FOAM_SRC/finiteVolume/fields/fvPatchFields/derived/codedFixedValue/codedFixedValueFvPatchField.H. Access to time is shown in example, you can access to face centres using patch().Cf() vector field. |
May 5, 2017, 05:48 |
Francesco
Hi to all,
i'm also interested on this topic. I trying to impose an internal (non bc!!), non-uniform, time varying, velocity field. specifically the field will should be Ux = 2sin^2(pi*x)*sin(2*pi*y)*sin(2*pi*z)*cos(2*pi*t/T) Uy = -sin(2*pi*x)*sin^2(pi*y)*sin(2*pi*z)*cos(2*pi*t/T) Uz = -sin(2*pi*x)*sin(2*pi*y)*sin^2(pi*z)*cos(2*pi*t/T) Any idea? Thanks Francesco |
May 6, 2017, 05:01 |
@phemt84 It depends. If it is your own solver: just set velocity, cycle through cells, get centres, calculate velocity. If you need this velocity in standard solver, you can use codedFunctionObject (you add code to codeExecute section, so you set velocity on every runTime++). |
May 8, 2017, 09:37 |
#5 | |
Francesco
first of all thanks for your answer. I will should use it with interFoam solver, specifically the result that i would like to obtain is this: https://www.youtube.com/watch?v=tW0S6V6tg9E I'm quite new in openFoam programming. Could you better explain the use of codedFunctionObject?? Thanks |
May 8, 2017, 10:21 |
#6 | |
interFoam solves NS for get velocity. You want to impose internal field. It looks a little bit bizarre. If you need something calculated with isoAdvector, why don't you got to isoAdvector repository and just download case files?
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Setting boundary conditions for simple pipe flow with flow direction changing in time | Sipher | FLUENT | 1 | May 4, 2015 20:05 |
Flow around cube and cube natural convection | Mirage12 | OpenFOAM Running, Solving & CFD | 5 | June 15, 2013 11:20 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
