"functions" subdictionary in controlDict for chtMultiRegionFoam
Like Tree6Likes
  • 2 Post By kera
  • 2 Post By stockzahn
  • 2 Post By oswald
Old   October 22, 2018, 17:27
Default "functions" subdictionary in controlDict for chtMultiRegionFoam
stockzahn's Avatar
stockzahn is on a distinguished road
Dear all,
using e.g. the simpleFoam solver I was able to save the residuals and display their evolution during solving by including "#includefunc residuals" in the subdictionary "functions" of the controlDict. However, if I do that with chtMultiRegionFoam, no "postProcessing" folder is created and no residuals are saved.
I also tried to include a function object based on the information here (https://www.openfoam.com/documentati...ieldValue.html) reading several threads here (according to which this should be possible, but they are quite old though). I tried to keep it simple for the first trials:
T0
type volFieldValue;
libs ("libfieldFunctionObjects.so");
log true;
writeControl writeTime;
writeFields true;
regionType all;
name titanium; //name of the solid region
operation none;
fields ( T );
In my understanding this function object should just copy the temperature field and name it "T0". Like with the residuals, there is no output, no error message, no info at all. However, could you tell where my mistake is or if this is not possible in chtMultiRegionFoam ?
Thanks in advance,
stockzahn
stockzahn is offline   Reply With Quote
Old   October 23, 2018, 04:39
Ricky
kera is on a distinguished road
Hallo stockzahn,
there is a discussion here on how to capture the field residuals for cht solvers. I still do it the old fashioned way by using PyFOAM.
As for your second try with functionObject.
|  \\    /   O peration     | Version:  2.3.0                               |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     chtMultiRegionSimpleFoam;
startFrom       latestTime;
startTime       0;
runTimeModifiable true;
functions
    minMax
        type            fieldMinMax;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled         true;
        log             false;
        write           true;
        region          air;   // Specify the region
        fields
          T
hope this helps!
Regards,
Ricky
PS: I am still using OF-2.3.x, OpenFOAM has come a long way since then.
Originally Posted by stockzahn View Post
Dear all,
T0
type volFieldValue;
log true;
writeFields true;
regionType all;
operation none;
fields ( T );
Thanks in advance,
stockzahn
Krapf and stockzahn like this.
If it is easy, then something is fishy!
kera is offline   Reply With Quote
Old   October 23, 2018, 10:11
stockzahn's Avatar
Thanks Ricky for your help. That's my status:
I tried it with
#includeEtc "caseDicts/postProcessing/numerical/residuals.cfg"
, but this only produced an error message:
--> FOAM FATAL ERROR:
 Cannot open etc file "caseDicts/postProcessing/numerical/residuals.cfg" while reading dictionary "/home/run/InTrCoilQ1/system/controlDict.functions.residualsTitanium"
From function static bool Foam::functionEntries::includeEtcEntry::execute(Foam::dictionary&, Foam::Istream&) in file db/dictionary/functionEntries/includeEtcEntry/includeEtcEntry.C at line 127.
 FOAM exiting
However, I then just copied the lines of "residuals.cfg" into the function subdictionary of the controlDict and it started to work. Key was to insert the lines
writeControl    timeStep;
 writeInterval    1;
also for the function object "T0". The functions of my controlDict now look like this:
functions
    residualsTitanium
    type     residuals;
    libs    ("libutilityFunctionObjects.so");
    writeInterval   1;
    regionType      all;
    region titanium;
    fields (T);
    sumT0
    type        volFieldValue;
    writeInterval   1;
     //writeFields          true;
    //regionType      all;
    region         titanium;
     operation    sum;
    fields        (T);
for the "sumT0" it works perfectly, but unfortunately in the residuals.dat file in the postProcessing folder displays "N/A" instead of the residuals.
Do you have or does anybody has an idea how to save the residual values in the .dat-file?
kostnermo and Krapf like this.
Old   October 24, 2018, 05:01
oswald is on a distinguished road
You should monitor "h", not T, as chtMultiRegionFoam solves for h.
granzer and stockzahn like this.
oswald is offline   Reply With Quote
Old   October 24, 2018, 07:12
stockzahn's Avatar
Thanks! So obvious, that wasn't very glorious of me ...
chtmultiregionfoam, function objects, residuals
InterFoam (PimpleFoam) not obeying DeltaT in ControlDict walakaka OpenFOAM Running, Solving & CFD 2 March 1, 2018 12:57
sampleDict and controlDict musahossein OpenFOAM Post-Processing 39 July 17, 2016 10:00
controlDict and sampleDict giving different results Shenan OpenFOAM Post-Processing 2 November 15, 2014 10:15
Forces not calculated when including a library in controlDict fusij OpenFOAM 2 May 13, 2011 07:25
writing controlDict as otherfields ubaid OpenFOAM 5 September 29, 2010 07:28
