Inlet and outlet profile are partially positive and negative at the same time
Old   January 18, 2019, 05:11
Default Inlet and outlet profile are partially positive and negative at the same time
Loek
Loekatoni is on a distinguished road
Dear foamers,
I have questions regarding and inlet profile which is partially negative and partially positive.
My model needs to become a horizontal channel (picture of schematics is added below). To limit the amount of gridcells, I am modelling a inifinitely small angle of the channel in the theta direction, practically making it a 2D problem. So now I have the top which is the wall of the channel, the bottom which is the centre of the channel and the left and right are respectively the in- and outlet of the channel and front and back are defined as empty.
Eventually I'm going to model flow, masstransfer and kinetics around a bubble. So the profile is kind of funky. The bubble is the reference frame. So I calculate the flowprofile of a liquid through a channel without the bubble via Hagen-Poiseuille and substract the bubble velocity to obtain the flowprofile for a system with a bubble as the frame of reference. When I do this, part of the final flow balance is negative and part is positive. If I try to use the codedFixedValue boundary, I get unphysical results. I haven't heard of another way to induce a profile on a boundary.
So my questions here are:
Does anybody has any experience with this kind of flow profile input?
Is there any other boundary to use to impose a profile on a boundary in which I write an equation?
Sincerely,
Loek
Loekatoni is offline   Reply With Quote
negative input for velocity inlet to make an outlet? Sipher FLUENT 1 June 24, 2015 02:51
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 12:30
the static pressure at one outlet is negative? yuhehuan Main CFD Forum 7 August 15, 2013 21:01
Modeling transient negative pressure (suction pressure) in outlet N_mrtz FLUENT 1 July 18, 2013 20:59
Negative pressure but Positive flow? ashrawage FLUENT 2 February 20, 2012 06:56
