Sigma surface tension - error when not using default values
Old   February 13, 2019, 05:28
Default Sigma surface tension - error when not using default values
Stefanie Wolf
Stefanie.S.W. is on a distinguished road
Hello everyone,
I am using multiphaseEulerFoam and I would like to use other values than the default value of 0.07 N/m for sigma.
transportProperties
sigmas
(air water) 0.07
(air oil) 0.07
(oil water) 0.07
But whenever I change one or all values the simulation stops after the first written time step, I get error messages like:
multiphaseEulerFoam >>log.solve
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 void Foam::multiply<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator*<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam"
#6 Foam::multiphaseSystem::dragCoeffs() const at ??:?
#7 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam"
Floating point exception (core dumped)
This specific error occurred when I changed all sigmas to 0.03. With the default values the simulation runs stable.
Does someone know why I can't change sigma? At some point I need to reduce the surface tension because I will use soapy water.
Thank you for your help!!
kind regards,
Stefanie
I am very uncertain which further information you need, hopefully I guessed right:
0 - alpha.air
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alpha.air;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    mischzylinder
        type            alphaContactAngle;
        thetaProperties ( ( oil air ) 90 0 0 0 ( water air ) 90 0 0 0 ( oil water ) 90 0 0 0 );
        value           uniform 1;
    duese
        value           uniform 1;
    zylinder
        value           uniform 0;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 1;
        value           uniform 1;
Alpha.oil and alpha.water are alike:
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.lml;
boundaryField
    mischzylinder
        type            zeroGradient;
    duese
        type            zeroGradient;
    zylinder
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
I also posted a related question here:
multiphaseEulerFoam-transportProperties dict
Stefanie.S.W. is offline   Reply With Quote
Old   July 2, 2020, 03:06
betterglobe is on a distinguished road
Did you fix your problem?
The 0.07 N/m default value is probably from the fact that the surface tension of water is 0.0728N/m at 20degC.
I'm not sure about why 0.03 N/m caused a problem. If the IFT drops to zero, the two phases will become mixed soup. So maybe the low IFT is bad for convergence?
betterglobe is offline   Reply With Quote
multiphaseeulerfoam, sigma, transportproperties
surface tension problem when using VOF+Solidification&melting models AlvinF FLUENT 4 April 22, 2024 10:31
Surface tension driven flows: interFoam vs. multiphaseInterFoam dzordz OpenFOAM Programming & Development 3 December 22, 2021 02:57
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
Surface tension values Apiano FLUENT 2 July 6, 2016 15:10
Access the surface tension force at a patch michielm OpenFOAM Programming & Development 1 December 13, 2013 03:50
