How to fixed water height in outlet
Like Tree3Likes
  • 1 Post By MDietrich
  • 1 Post By mcgoldba
  • 1 Post By So_LL
Old   April 2, 2019, 17:51
Default How to fixed water height in outlet
Marcos
MDietrich is on a distinguished road
Hi everyone.
I am modeling an natural river with a bridge. A am using interfoam for solver. I want to know how to fixed the water height in outlet to force the model to have that height at outlet. I want to know which Boundary Conditions must use. Tranks for you help.
lourencosm likes this.
MDietrich is offline   Reply With Quote
Old   December 17, 2020, 13:37
Grivalszki Péter
GrivalszkiP is on a distinguished road
Hi!
I have the same problem, did you get any solution?
Thanks,
Péter
GrivalszkiP is offline   Reply With Quote
Old   January 25, 2021, 09:43
Marc
mcgoldba is on a distinguished road
Same here. Any solution?
Thanks,
Marc
mcgoldba is offline   Reply With Quote
Old   January 25, 2021, 12:13
Federico
Federico_ is on a distinguished road
I posted something in similar below in which I use variableHeightFlowRate but I'd like to understand more about it. It should fix same values of alpha of the inlet with the mass conservation
Federico_ is offline   Reply With Quote
Old   January 25, 2021, 14:22
Marc
Hi Federico,
Thank you for the reply. I have tried something similar with the variableHeightFlowRate, however it didn't seem to work for me. I am attempting to simulate a water channel with something similar to an infinite reservoir at the outlet (with a fixed water level). However, the water level drops as the simulation progresses with the variableHeightFlowRate specification. I am now trying with a codedFixedValue boundary as follows. However, I am questioning whether or not it is a numerical issue since my mesh is somewhat coarse.
fixedWaterLevel
     code
         const vectorField Cf = patch().Cf();
         scalarField& field = *this;
         forAll(Cf, facei)
             field[facei]=(Cf[facei].y() <= -1.68584 ? 1 : 0);
Here -1.68584 is the constant water level I want to specify, and gravity is acting in the "y" direction.
Old   March 4, 2022, 06:50
Sophie
So_LL is on a distinguished road
Hi
Did you find a solution to this need?
I've seen elsewhere to fix the velocity of the outlet to V=Qinlet/Achannel for the depth you require, but this leads to a significant impact from the downstream BC on the modeled velocity. And if running LES, the need to extent the mesh further downstream is quickly overwhelming computationally.
Did you find a more elegant solution?
Mahmoud Abbaszadeh likes this.
So_LL is offline   Reply With Quote
Old   July 26, 2022, 04:44
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
Originally Posted by So_LL View Post
Hi
Hi. Have you found any solution?
Mahmoud Abbaszadeh is offline   Reply With Quote
Old   July 28, 2022, 02:32
Tobias
dalasrevo is on a distinguished road
I am working on a similar problem:
I have a section consisting of a basin open to the atmosphere at the top, fed by a lateral inlet. Then follows a piping (closed at the top, so a section under pressure, because the water level before and after the piping is higher), followed by a basin open to the atmosphere at the top.
The model is fed by a constant volume flow Q at the inlet. In reality, there is a flap at the outlet which keeps the water level in the lower basin constant at the desired level.
At the inlet I work so far with
inlet
type variableHeightFlowRateInletVelocity;
volumetricFlowRate 0.5;
flowRate 0.5;
alpha alpha.water;
value uniform (0 0 0);
But how do I keep the water level in the lower pool constant?
I have my patches open to the atmosphere with
top1
type pressureInletOutletVelocity;
defined.
Someone gave me the tip to "lower the model area by x cm", with x as the desired water level, but I can't figure out how to do that.
dalasrevo is offline   Reply With Quote
Old   September 13, 2022, 02:55
Kate Bradbrook
KateBradbrook is on a distinguished road
Hello, you can try the following:
make sure the file hRef exists in constant director with a line "value ***;"
Where *** is your desired outlet water level.
Then try the following outlet boundary conditions:
p_rgh
outlet
type totalPressure; //fixedValue also possible for static pressure
rho rho;
p0 uniform 0;
value uniform 0;
U
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value $internalField;
alpha.water
outlet
type zeroGradient;
KateBradbrook is offline   Reply With Quote
Old   September 21, 2022, 04:13
Tobias
I solved my problem with a different approach, namely by calculating the expected flux for my water phase at the outlet (using the area to determine the expected velocity) and then using the following boundary condition in U:
outlet
        type       outletPhaseMeanVelocity;
        Umean  XXX;
        alpha     alpha.water;
        value     uniform (0.312 0 0);
Old   August 27, 2023, 08:59
JCS
Verdant Frond is on a distinguished road
I have a (somewhat) similar case and this seems to be working well for my setup.
Thank you!
outlet
        Umean  XXX;
        alpha     alpha.water;
Verdant Frond is offline   Reply With Quote
boundary conditions, interfoam
Fixed water level BC alexvhn OpenFOAM Running, Solving & CFD 0 July 2, 2017 17:58
help: choosing density for water height flow_CH FLUENT 0 August 2, 2013 02:18
adjointShapeOptimizationFoam fixed outlet sailor79 OpenFOAM Running, Solving & CFD 14 December 6, 2011 08:55
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
