June 25, 2019, 09:47 |
Simulating object rotating within fluid
Ray
I am learning Simflow which uses openfoam as its backend so asking this question here as I am not aware of any simflow online community. I am trying to understand how to perform a simulation with a rotating object. There are two tutorials (links below), neither of which mesh the object to be rotated. In one example they use dynamic mesh to rotate one of the meshed fluid regions and in another they define a cell zone within the fluid and rotate the cell zone. What is happening and what is the difference between the two methods? It appears as if it is the fluid rather than the propeller that is being rotated but that makes no sense as the fluid elements would experience a centripetal acceleration.
https://help.sim-flow.com/userguide/propeller/ https://help.sim-flow.com/userguide/mixing-tank/ |
June 26, 2019, 10:32 |
Kmeti Rao
Rep Power: 8 |
Hi Ray,
Sorry I don't have any idea about Simflow but go through this link, which would help you to understand the difference between dynamic mesh and frozen rotor technique(where there is no actual mesh motion EX: MRF and SRF) https://www.slideshare.net/fumiyanoz...using-openfoam Krao |
dynamic mesh, rotating bodies |
Simulating a Rotating injector. | gokulravi.pgt | ANSYS | 1 | August 13, 2018 06:59 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 17:19 |
Calculation diverges, Liquid behavior around a rotating object | toru | OpenFOAM Running, Solving & CFD | 0 | December 1, 2016 10:54 |
simulating a stationary axis gas turbine with blades fixed in a rotating shell | lawbambace | OpenFOAM | 0 | January 5, 2016 09:35 |
flow solution of falling object in fluid with remeshing | bionic | CFX | 2 | September 20, 2010 01:31 |
