Changing a parameter (in my case voltage) between given period |
August 23, 2019, 06:01 |
X
Rep Power: 7 |
Hi there.
2 plates with potentials, 5kV and other ground. In 0 folder, I set the electric potential accordingly. For a different setup, I am trying to run this experimental case where "droplets enter this region when both electrodes are held at an identical high voltage between 2.8 and 3.4 kV creating a field-free region. The left electrode maintains a fixed HV while a stacked circuit of MTP1N100E MOSFETs switches the righthand plate from HV to ground and remains there for a variable time t ) 10-900 us before returning to high-voltage" (Grimm and Beauchamp, 2005) How can I set this configuration? I want to avoid running the simulation from 0 to 10 us and then changing the setting and then continuing. Paper - Dynamics of Field-Induced Droplet Ionization: Time-Resolved Studies of Distortion, Jetting, and Progeny Formation from Charged and Neutral Methanol Droplets Exposed to Strong Electric Fields Last edited by mcfdma; August 24, 2019 at 11:50. |
droplet ionization, droplet simulation, electrohydrodynamic, parameter set, parameter variation |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Changing gambit file without change of case file?? | Asghari | FLUENT | 2 | August 28, 2006 13:48 |
Turbulent Flat Plate Validation Case | Jonas Larsson | Main CFD Forum | 0 | April 2, 2004 10:25 |
Body force - Does it work? | Jan Rusås | CFX | 5 | August 27, 2002 09:50 |
