January 8, 2020, 13:30 |
noSlip and constantAlphaContactAngle
Josh McCraney
Rep Power: 8 |
Hi!
I'm modifying the damBreak tutorial. In the script 0/alpha.water.orig I can specify one of the walls as type constantAlphaContactAngle, thereby specifying the contact angle at the wall. In the script 0/U I can specify the same wall as type noSlip. However, when I run the tutorial now, we see that the velocity does slip along the advancing front (fluid moves up and down, splashing along the wall). Can someone explain why noSlip seemingly does not enforce the no-slip BC everywhere along the wall? |
November 11, 2021, 00:03 |
Similar issues with twophaseeulerfoam
Nevada
Rep Power: 12 |
Hi Josh,
Could you solve this issue? I am solving incline plane flow and seeing the solid phase sliding down noslip/fixedValue(0 0 0) wall. Since twophaseeulerfoam doesn't have alphacontactangle boundary implemented I am using zerogradient for alpha at wall. Do you think implementing alphacontactangle boundary would help in my case? |
November 11, 2021, 00:27 |
#3 | |
Josh McCraney
Rep Power: 8 |
rightWall{ type fixedValue; value uniform 0; } in the p_rgh try rightWall{ type fixedFluxPressure value 0; } and try noSlip in the U file. This should work; it worked for me via interFoam. |
Problem with boundary layer - noSlip condition not being respected - OpenFOAM | heitorvitorc | OpenFOAM Post-Processing | 1 | August 14, 2019 05:14 |
slip & noslip boundary condition for dynamic mesh, how to implement? | oschi | OpenFOAM Programming & Development | 6 | May 21, 2019 04:33 |
Sonicfoam Forward Step Modification - NoSlip not working. | Bilderberg | OpenFOAM Running, Solving & CFD | 0 | April 18, 2019 12:27 |
multiphaseEulerFoam/tank discharge | ves | OpenFOAM Running, Solving & CFD | 8 | December 31, 2017 14:59 |
Problem where FixedValue Inlet meets noSlip Wall | VSass | OpenFOAM Pre-Processing | 0 | May 31, 2013 05:13 |
