Calculation of turbulence kinetic energy and dissipation rate
Old   February 11, 2020, 21:33
Default Calculation of turbulence kinetic energy and dissipation rate
Mondal131211's Avatar
Mondal
Mondal131211 is on a distinguished road
Hi Foamers,
Hope all of you are doing well. I am now working on pure natural convection along a heated plate which is a well known topic in CFD. Actually, the reason of my post is about initializing the turbulent kinetic energy (k) and dissipation rate (omega) for a pure natural convection. I know how to calculate k and omega for forced convection using the formula,
k=3/2*(I*U)^2 (I-Tur intensity, U-Reference Velocity).................(1)
omega=k^0.5/(Cmu*l) (Found in OpenFOAM documentation).............(2)
For a forced convection I can easily get the the value of k from Eqn (1) using velocity U. Once I get the value of k, I am also able to calculate omega.
But for a pure natural convection, how can we know the exact velocity? As I know so far velocity depends on density differences for a pure natural convection.
Lets assume the value of k is zero for natural convection as there is no exact velocity. Then how can I calculate omega except k from Eqn (2)?
I am really confused about this silly question. I hope there are lots of people out here to clear my confusion about this topics. If I am unable to understand you about my topics, plz feel free to ask me more info. I am happy to give more information.
Thank you very much in advance.
Cheers
Razon
Mondal131211 is offline   Reply With Quote
Old   May 29, 2020, 04:17
geth03 is on a distinguished road
did you run a few simulations just to see how sensitive your simulation is to initial values of k and omega??
when i run simulations, regardless of the initial value for those, the same value will be calculated after some time and after that i get the same results.
would you share your 0-directory files for those?
geth03 is offline   Reply With Quote
Constant Residual of Turbulence Kinetic Energy and Dissipation Rate wrightguy FLUENT 4 June 20, 2021 10:19
Calculation of Turbulent kinetic energy and turbulent dissipation rate Mondal131211 OpenFOAM Pre-Processing 1 October 13, 2019 21:29
Turbulence kinetic energy and dissipation rate - problem with computation Kozan Main CFD Forum 0 March 6, 2015 04:04
change a variable in dissipation tem of turbulence model behest Fluent UDF and Scheme Programming 0 March 28, 2014 08:31
turbulent kinetic energy and turbulent dissipation rate D_L Main CFD Forum 5 July 17, 2010 02:35
