February 26, 2020, 23:33 |
How to Choose or set BC’s?
Muhammad Kashif Jawad
Rep Power: 5 |
Is there anyone who can help me set up interfoam case?
In my case , my geometry is like T-shape channel, with two inlets and one outlet. I know discharges at inlets and at outlet i know depth, velocity and combined discharge. I tried alot, I don’t understand whether I’m using wrong BC’s or It is not converged or something else... but not getting the expected results. I didn’t find any file explaining BC’s when and where to apply.. completely confused. Here are my files... https://-my.sharepoint.com/:f:/g/personal/mjawad_ms18nice_student_nust_edu_pk/--IB0gSnRQNKrntQRmkKbvgrig?e=eiKM59 Any help would be appreciated... Thanks in Advance. Regards. Last edited by mkjmalik; March 3, 2020 at 15:26. Reason: I don’t want to share my files |
May 29, 2020, 04:10 |
Rep Power: 8 |
can you elaborate ?
what are your inlet BC's and your outlet BC? |
May 29, 2020, 04:54 |
Rep Power: 5 |
I got my results thankss by changing BC’s
May 29, 2020, 18:19 |
Herpes Free Engineer
Rep Power: 12 |
Why did you share your files to get help - and then stop sharing by removing the link (even stating:`I don't want to share my files`) once you get a solution to your problem?
Everyone is spending their free time here - contributing each other. Trump..
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
[mesh manipulation] mirrorMesh and undoing the joining of patches | chegdan | OpenFOAM Meshing & Mesh Conversion | 3 | October 21, 2015 08:09 |
Install problem in linux | navaladi | OpenFOAM Installation | 11 | July 17, 2008 02:24 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Ibm java gcc | rrr | OpenFOAM Installation | 2 | December 30, 2005 04:18 |
