April 16, 2020, 05:37 |
totalPressure Inlet boundary condition
LouisDS
Rep Power: 6 |
Dear OpenFOAM users,
Situation sketch: I am modelling a ship propeller in a canal. The ship is under bullard pull condition, so the inlet velocity has to be equal to 0 m/s. The inlet is far upstream of the propeller and as a consequence it doesn't feel any influence of the propeller. This means the pressure close to inlet has to be equal to the ambient pressure ( p = 0) I am using the totalPressure boundary condition and I have put p0 at a value equal to zero. For U, I am using the pressureInletVelocity (uniform (0 0 0)) boundary condition. My goal is to get the ambient pressure at the inlet and an inlet velocity equal to 0 m/s. However, with this BC combination and by looking at my results, the totalpressure is not zero at the inlet boundary and the velocity is also not equal to zero. Is there any way to make both the pressure and the velocity equal to zero at the inlet? I have tried fixedValue for both U an p, but this also does not work. Thanks in advance and kind regards, Louis Last edited by loewieke53; April 17, 2020 at 14:02. |
April 16, 2020, 07:05 |
Thiago Parente Lima
Hi loewieke53,
I am having the same problem with this boundary condition too, but in a buoyancy driven flow. Try to clarify better your case (a figure maybe) showing where exactly you are trying to set the totalPressure. Have you tried fixedFluxPressure for p and inletOutlet for U with inletValue (0 0 0)? This way you force zero velocity at the inlet, but I don't know whether this satisfies the physics of your case.
Fields of interest: buoyantFoam, chtMultRegionFoam. |
April 16, 2020, 07:45 |
LouisDS
Rep Power: 6 |
Hi Thiago,
Currently my result closest to my final goal is when I use: - fixedValue (0 0 0) for U - zeroGradient for p My screenshots show the resulting velocity and pressure distribution in a side view of the canal. The small propeller with a diameter of 7.5 cm is located at 1.51 m from the inlet. The plot shows the values of the velocity/pressure on a line trough the propeller centerline. As you can see, with these BCs. I managed to put the velocity at the inlet to 0 m/s. But the pressure assymptotically goes to a value under 0. In reality it would go assymptotically to a value of 0 (ambient pressure) as here no influence of the propeller is felt. With the totalPressure BC, both velocity and pressure are not zero at the boundary. If you want me to add these results please tell me. I will now try your boundary condition and check the results. Thank you very much! Last edited by loewieke53; April 16, 2020 at 10:27. |
April 16, 2020, 09:49 |
LouisDS
Rep Power: 6 |
Dear Thiago,
I have tried your boundary conditions but I get the following error: [3] --> FOAM FATAL ERROR: [3] updateCoeffs(const scalarField& snGradp) MUST be called before updateCoeffs() or evaluate() to set the boundary gradient. [3] [3] From function fixedFluxPressureFvPatchScalarField::updateCoeffs( ) [3] in file fields/fvPatchFields/derived/fixedFluxPressure/fixedFluxPressureFvPatchScalarField.C at line 151. Do you know what could be wrong? I am running in OpenFOAM 2.4. My case is added as a attachment. |
April 16, 2020, 13:57 |
Thiago Parente Lima
Hi loewieke53,
I ran your case in OpenFoam 7 and got no errors message (see bellow). Your domain is a channel with a inlet, outlet and the top surface is openned to the atmosphere, right? Once you have a propeller within the channel, zero velocity should not be expected at inlet nor outlet. Try zeroGradient for velocity on both, noSlip on walls and slip condition on the top patch ('bed'). For pressure I would try fixedFluxPressure on walls and zeroGradient on inlet, outlet and the top surface and see what happens... Another try is the combination of totalPressure and pressureInletOutlet velocity also on inlet, outlet and top surface. But I am having a lot of troubles with that in a buoyancy solver. Note: something is not going well with your pressure, see the number of interations. Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-1ff648926f77 Exec : simpleFoam -parallel Date : Apr 16 2020 Time : 14:33:28 Host : "thiago" PID : 8613 I/O : uncollated Case : /home/thiago/OpenFOAM/thiago-6/run/CDF_forum nProcs : 4 Slaves : 3 ( "thiago.8614" "thiago.8615" "thiago.8616" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 // using new solver syntax: p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.01; } // using new solver syntax: U { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } // using new solver syntax: k { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } // using new solver syntax: epsilon { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } // using new solver syntax: R { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } // using new solver syntax: nuTilda { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } SIMPLE: No convergence criteria found Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model realizableKE RAS { RASModel realizableKE; turbulence on; printCoeffs on; A0 4; C2 1.9; sigmak 1; sigmaEps 1.2; } No MRF models present No finite volume options present Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0100108, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.00284327, Final residual = 4.51522e-05, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.000303705, Final residual = 2.72132e-05, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00999426, No Iterations 579 time step continuity errors : sum local = 1.05153e-13, global = 3.50588e-16, cumulative = 3.50588e-16 DILUPBiCG: Solving for epsilon, Initial residual = 0.0645732, Final residual = 0.00425372, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0911234, No Iterations 1 ExecutionTime = 39.54 s ClockTime = 45 s Time = 2 DILUPBiCG: Solving for Ux, Initial residual = 0.355491, Final residual = 0.00515955, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.67132, Final residual = 0.00362789, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.673923, Final residual = 0.00409022, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.413749, Final residual = 0.00397229, No Iterations 580 time step continuity errors : sum local = 2.48489e-12, global = -6.52431e-15, cumulative = -6.17372e-15 DILUPBiCG: Solving for epsilon, Initial residual = 0.0147397, Final residual = 0.00122171, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.724191, Final residual = 0.00615031, No Iterations 2 ExecutionTime = 73.88 s ClockTime = 83 s Time = 3 DILUPBiCG: Solving for Ux, Initial residual = 0.201439, Final residual = 0.0146159, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.543944, Final residual = 0.0412652, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.545317, Final residual = 0.00242244, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.0181324, Final residual = 0.000169874, No Iterations 561 time step continuity errors : sum local = 4.55376e-12, global = -1.58739e-14, cumulative = -2.20476e-14 DILUPBiCG: Solving for epsilon, Initial residual = 0.0195868, Final residual = 0.00126217, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.102215, Final residual = 0.000705285, No Iterations 2 ExecutionTime = 107.02 s ClockTime = 123 s Time = 4 DILUPBiCG: Solving for Ux, Initial residual = 0.229894, Final residual = 0.00674323, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.318536, Final residual = 0.0101073, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.256109, Final residual = 0.011179, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.0103171, Final residual = 9.64873e-05, No Iterations 565 time step continuity errors : sum local = 3.63496e-12, global = -2.45663e-14, cumulative = -4.66139e-14 DILUPBiCG: Solving for epsilon, Initial residual = 0.0204973, Final residual = 0.00143584, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.058776, Final residual = 0.0041336, No Iterations 1 ExecutionTime = 141.38 s ClockTime = 163 s
Fields of interest: buoyantFoam, chtMultRegionFoam. Last edited by thiagopl; April 16, 2020 at 14:01. Reason: Grammar and note. |
April 16, 2020, 16:16 |
LouisDS
Rep Power: 6 |
Hi Thiago,
I still cannot use the fixedFluxPressure bc. This part in the "fixedFluxPressureFvPatchScalarField.C" file is causing my error. Do you know how to fix it maybe? That would be a great help void Foam::fixedFluxPressureFvPatchScalarField::updateC oeffs() { if (updated()) { return; } if (curTimeIndex_ != this->db().time().timeIndex()) { FatalErrorIn("fixedFluxPressureFvPatchScalarField: :updateCoeffs()") << "updateCoeffs(const scalarField& snGradp) MUST be called before" " updateCoeffs() or evaluate() to set the boundary gradient." << exit(FatalError); } } Thank you in advance and kind regards UPDATE: I have now tried the freestreamPressure boundary condition (together with freestream uniform ( 0 0 0) for U) and this one works. According to the .H file this is the definition of the boundary "This boundary condition provides a free-stream condition for pressure. It is a zero-gradient condition that constrains the flux across the patch based on the free-stream velocity." So in my opinion it will do the same as the fixedFluxPressure bc, or am I wrong? Last edited by loewieke53; April 17, 2020 at 04:12. |
April 17, 2020, 07:29 |
#7 | ||
Thiago Parente Lima
loewieke53,
I suggest you to upgrade your OpenFoam to version 7. Your case runs on it, so. Instead of fixedFluxPressure you can use zeroGradient also. According to the User Guide: Quote:
April 18, 2020, 03:35 |
LouisDS
Rep Power: 6 |
Thiago,
I updated to OpenFOAM 7 an also adapted the simpleFoam solver to let it recognize the actuator Disc region of the propeller. source: http://www.tfd.chalmers.se/~hani/kur...ningReport.pdf This was btw the reason why I worked in such an old version of Openfoam, because I followed this tutorial (you had to adapt the simpleFoam solver and this didn't work for OF7, untill now) After updating and running my older script (with zeroGradient, see screenshots above) I saw that my maximal velocity increased with about 16 %. This is something very strange, because I only updated to OF7 and didn't change anything else. OF7 also makes a Q-variable and an omega-variable, which I did not saw in the older versions, is this normal? The good news is that I managed to implement the fixedFluxPressure BC. For the inlet, I used inletoutlet for U and fixedFluxPressure for p. The result is added as a screenshot. Sadly the pressure still asymptotically goes to a value under 0. I will try some other BCs and let you now. A last question: As you also noticed, I get a high number of iterations for p. Do you maybe have an explanation for this phenomenon? That would be a great help. Kind regards, Louis |
April 21, 2020, 08:29 |
Thiago Parente Lima
Louis,
I changed the p solver to the common setup used in tutorials: Code:
// p PCG // { // preconditioner DIC; // tolerance 1e-06; // relTol 0.01; p { solver GAMG; tolerance 1e-6; relTol 0.01; smoother GaussSeidel; }; Code:
Time = 26 DILUPBiCG: Solving for Ux, Initial residual = 0.0110521, Final residual = 0.000533473, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.012833, Final residual = 8.69934e-05, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.0097166, Final residual = 0.000112887, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0270312, Final residual = 0.000256905, No Iterations 21 time step continuity errors : sum local = 1.54414e-12, global = -5.92451e-13, cumulative = 6.42263e-13 DILUPBiCG: Solving for epsilon, Initial residual = 0.0108551, Final residual = 0.000472, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.0186211, Final residual = 0.000416674, No Iterations 1 ExecutionTime = 294.26 s ClockTime = 334 s Time = 27 DILUPBiCG: Solving for Ux, Initial residual = 0.0105428, Final residual = 0.000411424, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.0120645, Final residual = 8.76166e-05, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.00937806, Final residual = 0.000115178, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0291473, Final residual = 0.000254077, No Iterations 5 time step continuity errors : sum local = 1.51797e-12, global = -5.11688e-13, cumulative = 1.30575e-13 DILUPBiCG: Solving for epsilon, Initial residual = 0.0111433, Final residual = 0.0004658, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.0182348, Final residual = 0.000407091, No Iterations 1 ExecutionTime = 299.51 s ClockTime = 340 s P.S.: the spam filter of the forum is really annoying and blocks every message I try to post.
Acoustic boundary condition with pressure perturbation at inlet | hand90 | CFX | 2 | August 10, 2018 07:36 |
UDF fluent:Change boundary condition. determination inlet and outlet boundary in "t" | gzamiri@gmail.com | FLUENT | 0 | September 27, 2015 05:32 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
