Run multiple cases simultaneously in parallel?
Like Tree2Likes
  • 1 Post By mzzmrt
  • 1 Post By lebc
Old   April 16, 2020, 22:14
Default Run multiple cases simultaneously in parallel?
Josh McCraney
joshmccraney is on a distinguished road
Hi FOAMers!
I have 16 cores available, and would like to run 4 different cases simultaneously, each on 4 cores. Is this possible? Is it as simple as simply running
mpirun -np 4 interFoam -parallel
or do I need to tell the system which 4 to use so that it's using all 16?
joshmccraney is offline   Reply With Quote
Old   April 17, 2020, 05:31
mzzmrt is on a distinguished road
I guess you can. Just open four terminals run each case simultaneously.
Of course you have to partition the grids first for parallel processing.
mzzmrt is offline   Reply With Quote
Old   April 17, 2020, 18:50
Josh McCraney
So the computer is just smart enough to know not to reuse old cores?
Old   April 18, 2020, 04:26
I made a test and understood that my guess is wrong!
Old   April 19, 2020, 18:13
Well, just found the solution. An additional command "cpu-set" is needed:
mpirun -np 2 --cpu-set 0-3 pisoFoam -parallel (for assigning fist four cores)
mpirun -np 2 --cpu-set 4-7 pisoFoam -parallel (for assigning second four cores)
so on...
joshmccraney likes this.
Old   April 20, 2020, 12:13
Luis Eduardo
lebc is on a distinguished road
You can also use the "--bind-to socket" or "--bind-to core" option, it works fine!
lebc is offline   Reply With Quote
SimpleFoam cannot open include file Marija OpenFOAM Running, Solving & CFD 1 October 28, 2020 10:35
how to automatically run multiple cases in batch mode breezeyu STAR-CCM+ 1 June 11, 2018 06:45
Parallel run: bool ipstream::init attempt to run parallel on 1 processor SarahLee OpenFOAM Running, Solving & CFD 2 January 11, 2017 03:24
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
Change parameter and run cases parallel lingdeer ANSYS 0 July 29, 2011 10:27
